Results 1 to 16 of 16
Thread: Slamming an indoor pool
    Nov 2014
    United Kingdom
    220
    Is there any difference between slamming an indoor pool against an outdoor pool
    FC 2.6
    CC 2.4
    PH 7.6
    TA 100
    CH 480
    CA 20
    Temp 30 Celsius
    10,000 gallons inground Leisure fibreglass pool, Hayward powerline pump, Quality120 glass media filter, 27kw output air source heat pump and thermal cover.
    Retractable cover with Polycarbonate roof and glass side for all year round use. K-2006C test kit and Speed stir
    Jun 2014
    15,249
    Re: Slamming an indoor pool
    Not really, other than your levels will be a little lower since you normally have a lower CYA. So with a CYA of about 20, your SLAM FC value will be at about 10. You'll still want to lower pH to the 7.2-7.4 range, even though you don't expect to have a really high FC (over 10), but it is still part of the SLAM protocol. Everything else on the SLAM page should still apply. Good luck!
    Nov 2014
    United Kingdom
    220
    Thanks for that
    I couldn't find anywhere on the site about indoor pools
    Nov 2014
    United Kingdom
    220
    Does anyone have a link to a pool level chemical log sheet
    Jun 2014
    15,249
    They are in the bottom of my signature. Or are you referring that historical product known as "Jesse's Spreadsheet"?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    One thing with indoor pools, when doing SLAM you don't want to go too much over SLAM level as it takes a LONG time for FC to drop if you overshoot.
    Let me ask though, what is the current condition of the pool, how does it look?
    Also have you been using any MPS based non chlorine shock products?
    Nov 2014
    United Kingdom
    220
    It's a bit cloudy after doing an AA stain treatment and finishing it of with an underwater acid wash
    I have only been using sodium hypochlorite 13.5%
    Nov 2014
    United Kingdom
    220
    I have virtually finished slamming but still have cloudy water which doesn't settle
    I have vacuumed but there was very little to remove
    There is a flocculant in the filter from the pump skimmer basket
    The image is at a depth of 3.5 feet
    Jun 2014
    15,249
    I would recommend continuing the SLAM since you do need to pass all 3 SLAM criteria (link below) - clear water being one of the requirements. As for the Floc, those products have their place at times but can also cause more problems than what they're worth - especially in a filter. If you haven't deep cleaned your filter this season I would recommend you do so following the Deep Cleaning a Sand Filter page.
    Once you pass the OCLT and CCs are no more thab 0.5ppm, then you might consider adding a little DE to help your sand as noted on the Pool School - Add DE to a Sand Filter page. But make sure to do the deep cleaning first.
    Nov 2014
    United Kingdom
    220
    How much DE should be added to the filter, so that I know how much to purchase
    Jun 2014
    15,249
    Please reference the link provided above. You don't need much. Just enough to increase psi by one.
    JoyfulNoise's Avatar
    May 2015
    13,251
    Is the flocculant removed?
    Normally you add floc directly to the pool water, let it mix for an hour and then shut the pumps off. The next day there should be a flocc'd layer of sediment on the pool floor that you vacuum out to waste. You always vacuum floc to waste, never through the filter or else you will clog the filter or, if fine enough, the sediment you flocc'd will shoot past the filter and go right back into the pool.
    You should never add flocc to the filter by putting it in the skimmer. Not only can you clog up your filter but you can also over-flocc your pool water which actually CAUSES more cloudiness by resuspension of fine particles.
    Matt
    Nov 2014
    United Kingdom
    220
    Being as I don't need much I have been looking on Ebay and have come across food grade Diatomaceous Earth is this the same?
    The flocculant is removed and a deep clean done on the filter. I have also started the OCLT. My indoor pool has a thermal blanket over it so it should be unaffected by the sun
    Isaac-1's Avatar
    SW Louisiana
    6,711
    No, it is not. Pool filter DE is heat treated to fracture the DE particles and make them sharp and catch stuff, this is also a big part of what makes them an inhalation risk.
    May 2015
    13,251
    Like Isaac-1 said.... NOOOOOOOOOOOOO!!!!
    Do not put food grade DE in your pool, it will create a HUGE mess!!
    Matt
    Nov 2014
    United Kingdom
    220
    I'm glad I asked
    Thanks
