Thread: Slope question
    Jul 2016
    shadyside, ohio
    5
    Slope question
    Hello all, I am building a DIY pool kit and after laser leveling the site found that my deep end wall would be exposed 36" above grade. Not a big problem with backfill but due to the slope I am forced to build about a 4 1/2 foot retaining wall 6 feet away from the pool wall and then backfill. Any thoughts from anyone or has someone dealt with this issue? I am looking to pour concrete footer and poured concrete block retaining wall running 76 feet long.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Slope question
    In California a 4 1/2 foot retaining wall would require plans stamped by an engineer.
    You might want to get some contractors bids and see how local contractors handle the situation. What kind and size of footer, etc. There may be construction methods that are acceptable that do not require a footer.
    Feb 2016
    Atlanta, GA
    145
    Re: Slope question
    Why six feet away? Is it your property line or that's just to limit backfill required?
    If you have more room you could stagger/tier two shorter walls to be under the height requirement that needs a engineers stamp. Shorter walls also mean you could use simpler wall blocks and no footer.
    Jul 2016
    shadyside, ohio
    5
    Re: Slope question
    Footer will be 4000psi concrete w/rebar. 14" W and 8" D. At least that is what I was planning.
    Quote Originally Posted by allinspector View Post
    6 feet was allowing 4 feet+ for the sidewalk around the pool.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Re: Slope question
    Just for kicks, you can check out our build thread in my signature. Our pool is on a substantial slope but we had a decidedly non-DIY retaining wall structure built that completely encircles the pool. It is a StoneMakers licensed method of installing concrete vertically without forms and then carving it. The wall provides support for the our deck on that side of the pool. Then the entire retaining wall (except for one corner) was backfilled against so you don't even know it's there.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jul 2016
    shadyside, ohio
    5
    Re: Slope question
    Beautiful pool, bmoreswim. I really like the look of that wall. I will definitely check into that and see if it stays within the budget. Thanks!
