Thread: Replacing Hayward DE Filter
    Sep 2007
    Tinley Park, Illinois
    74
    Hi. I need to replace my Hayward DE Filter. I currently have a Hayward EC45 DE Filter with a 1.5HP motor. The motor is fine but I have to replace the filter. I cannot find the EC45 model anymore. They sell the EC40 and the EC50. Can I use the EC40 with a 1.5HP motor? If not, will it work with the EC50?
    Any help would be greatly appreciated. I am ready to hit the "buy" button on Amazon but don't want to purchase the wrong filter for my motor size. Thanks in advance.
    24 ft. round Artesian above-ground pool
    54" depth
    15,000 gallons
    Hayward 1.5 HP EC45 DE Filter
    Hayward H150 Gas Heater
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Replacing Hayward DE Filter
    We always say bigger is better, the bigger the filter the longer you can go without cleaning the filter..
    Sep 2007
    74
    Quote Originally Posted by cowboycasey View Post
    I will purchase the larger filter. Thanks!
    54" depth
    15,000 gallons
    Sep 2007
    74
    Just following up. I ended up sending an email to Hayward and they said that I could buy the smaller filter. It actually is the replacement of the one I had. We purchased it on Amazon and it arrived in two days. It's now hooked up and everything is running great. I now have another problem but will start another post. Thanks!
    54" depth
    15,000 gallons
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Sure you can buy the smaller one if you want to clean it more often.....
