Results 1 to 8 of 8
Thread: New Guy with new Pool
    TechnoGeek's Avatar
    Jul 2016
    Terre Haute, Indiana
    36
    Hi, just found this while searching for help and really liked it so i registered.
    I just completed my First Pool setup. A Oval 18x33x52. The Ground is level within 1/4 inch anywhere thanks to a borrowed transit. The elevation required me to dig down about 25 inches on one end to get it level on the low end. The straight section buttresses setup was well lets just say very involved.
    After getting it All setup and Filled I noticed one buttress was leaning out and the foot was lifting . Called the Mfr they suggested I empty the $600 of water. From sandy soft soil and generous liquid sunshine the buttress support blocks required a bit more support so it sank down about 1.5 inches.
    The fix was to dig two holes beside the buttress/support blocks re-level and fill with 5000 psi concrete. I added 1 yard more of sand by buckets tossing over the wall (total 2 1/2 inches now) and reinstalled the Liner. Matched the skimmer hole best I could and used the 'Big Vinyl Patch kit' for the difference.
    I feel I could give some good info to anyone doing an oval pool now that I have experienced this event. I know a support person at the Mfr now reasonably well. James and I have worked thru a lot of concerns, worries, encouragement, etc...
    I am still digesting all this chemical level stuff, I do Computer Servers and Networking and it is way easier that pool chemicals
    Glad to be here now.
    18'x33'x52" Sams Club version of Swim-n-Play Ridgeview 14K Gallon AGP, 19" SandFilter, 35 GPM 1HP pump
    TF-100 Kit, My other Fun is a Victory CrossRoads American Made Bike
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    Re: New Guy with new Pool
    Welcome,
    The pool balancing is just a small learning curve. Congrads on your pool
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    Aug 2014
    Northern IL
    4,615
    Did you get a testkit?
    Casey's Avatar
    SW PA
    10,418
    How about some pics of that brand new pool?!
    TechnoGeek's Avatar
    Jul 2016
    36
    My new Pool 2 days after filling it with water.
    Rained pretty hard and had to drain off about 3 inches.
    The Rain raised the water about a half inch over skimmer. The hole at the skimmer top was like a mini fountain.
    I drained it to about mid way on the skimmer which I assumed was the right level.
    Any suggestions what to do about a small deck?
    The ladder is a definite issue for me.
    I'm open to any ideas....
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,750
    Nice job on the pool it looms great. Above ground pools can really benefit from having deck access. I have yet to here from anyone who wishes they had a smaller deck for their pool. The sky is the limit for options from some pre built kits to full custom hand built masterpiece. There are specific safety rules regarding access decks for pools so check with your local building department before getting to carried away. The straight edge on an oval pool is a perfect place to start for an easy rectangular deck. Wrapping the deck around the curved ends makes for a harder build but can look really elegant. If I can ever get my deck completed I will post some pics of it.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Casey's Avatar
    SW PA
    10,418
    I'd put the deck on the back side by the shed. With steps coming down the right side of the pool. Anything is possible. Decks make it easier to access and sweep the pool too.
