Thread: Pump Runtime
    Jul 2016
    Saskatchewan
    6
    Pump Runtime
    Now that I finally have clear water and levels are all balanced, what should I set my timer for run time of my pump?
    Intex 16' Above Ground Pool 3800 gallons
    Krystal Clear Cartdridge Filter Pump 1,000 gph flow rate
    May 2016
    Swansea MA
    62
    Re: Pump Runtime
    Really depends on trees in the area and bugs in the area. Things like that I get very few leaves in my pool. I run mine 4 hrs total.2 hours in the morning to grab any bugs from the overnight before the kids go in the afternoon. Then 2 hours at night so I can test and add chemicals. It really depends on your needs. Start at 6 hrs and keep going down by an hour until you notice it's not as clean as you would like then add that last hour back. Just an idea with how I do it.
    24 ft round AG 12,700 gal. vinyl
    Doughboy Sequel II Rotary DE filter
    TF-100 test kit. 1st full season
