Thread: What Level of CYA
    What Level of CYA
    What level of CYA should i have in my hot tub? Also i would like to keep as low a Chlorine level as possible 1ppm or 2ppm.
    Located in Ottawa, Ontario Canada
    23K Gal, AG, Cart filter, 1.5hp 2speed hay PowerFlo Matrix, Install Sum'13, Aquatrol SWG, Solarbear panels, kreepy Krauly E-Z Vac, TF-100
    Artesian ~500gal Grand Gayman Island Spa
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: What Level of CYA
    I would use 30 ppm and this process, How do I use Chlorine in my Spa (or pool)?. I've been using it for years and it works great.
