Thread: Thank you!
    Teresathurman's Avatar
    Jun 2016
    Arab al.
    3
    Thank you!
    Hi I'm Teresa and I posted a few weeks ago. I would like to say thanks. I got my test kit, tf100, and my pool is clear as a bell, after a severe case of mustard algae! My cya is still a little high at 80, so trying to stay at 9 for FC. Ph is 7.8, TA is 110, FC was 4 today and CC is 0.5. I added the recommended bleach to raise free chlorine. I'm getting the hang of this and I can't believe how beautifully clear my pool is. Thank u so much! So my question is how much bleach can I daily add to maintain a ph if 9 without having to do the Chlorine drop test?
    Thanks again 😊
    Teresa
    Above ground pool, vinyl liner, round , 14000 gal. Six years old. Sand filter, 1 speed pump.
    Jun 2014
    15,153
    Re: Thank you!
    Glad to hear you are doing so well. Your water looks fantastic. About your question ...
    If you are asking how to maintain an FC of 9, simply continue to use the Poolmath calculator (link below & home page). In fact, use the calculator for all chemical doses. That's what it's there for. If you still have a question, please let us know.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Thank you!
    Squirrel!
    Alright! That is awesome. Nice pool!
    Want to add a nifty badge to your profile? See this
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,250
    Re: Thank you!
    That's a great story to hear Welcome to TFP and it's great to hear you were able to work through it using all the great resources here.
    Some people track their testing and dosing over time and keep a log. After a time (and this varies by pool and usage), they see a pattern that allows for less than daily testing. It takes time, and there's no recipe because of the unique needs of each pool, which reflect bather load, weather, and incoming contamination such as leaves, dust, critters, and the like.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
