Thread: PacFab PF35 sand filter - fill level
    May 2016
    Victoria, TX
    9
    Anyone familiar with the PacFab PF-35? I see there is a groove showing on the inside at the top of the bottom half of the filter. Is this the fill level that the filter media should be below?
    Thanks
    Samtex
    Apr 2015
    tucson, arizona
    1,118
    Re: PacFab PF35 sand filter - fill level
    Usually if you fill a sand filter to around the top of the upper piping assy. you should be good. On a lot of filters that is were there is a seem around the tank
    May 2016
    Victoria, TX
    9
    Quote Originally Posted by kadavis View Post
    That's what I was thinking, that will keep the media about 1 1/2" away from the bottom of the round head of the diffuser assembly. I guess it will settle a bit also.
    Appreciate your help.
    Samtex
    May 2011
    Long Grove, IL
    117
    I tried to attach a copy of the manual but apparently, it is too large. I will try to send you a PM.
    It took a few calls to Pentair before I was able to get in touch with someone who could help.
    Regards,
    Jay
    Quote Originally Posted by samtex View Post
    Thanks
    Samtex
    Jay
    28,000 gal in-ground hybrid pool with PacFab Superflow 100 sand filter witn VitroClean media, Intelliflo VS pump, Stenner chlorine pump, Raypak R336A Millivolt Natural Gas Pool Heater
