Thread: Intex pool with green water
    Jul 2016
    North Plainfield, NJ
    2
    Hello,
    We have been dealing with green water that is murky as the water gets deeper (seen on white walk in pool ladder) for about four weeks, upon returning from a week long vacation. Three weeks ago we shocked it with four bags of shock and it turned to blue again, but was still slightly cloudy.
    We are now back to full on green water. According to Leslie Pool we had these values: FC 5, TAC 5, CH 200, CYA 90, TA 90, pH 7.4, Copper 0, Iron ).
    We have been using a robotic automatic pool vaccum that is electric (not running off pool suction) that has been picking up minimal leaves. The pool pump has been running continuously for 36 hours.
    Added chlorine free shock yesterday and today and are still left green water. The amount added over the two days combined was enough for 16,000 gallons. Did not have this problem at all last year.
    Any suggestions you could be provide would be appreciated!
    Michele
    8600 gal, AG, Intex 18 X 52 Ultra Frame
    Intex Krystal clear 0.50HP
    Re-installed this year
    Leslie's Water Analysis
    Town Water
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Intex pool with green water
    Welcome to TFP!
    This is how we kill algae, SLAM
    You will need a good test kit, I use the TF-100 from TFTestkits.net. it is the best value, here's why, Pool School - Test Kits Compared
    Do some reading in Pool School to learn a bit more about caring for your pool.
    Start here, ABCs of Pool Water Chemistry
    And here, Pool School - Getting Started
    domct203's Avatar
    Jun 2015
    CT
    3,587
    Welcome!
    Stop using pucks or throwing in bags of shock. Both those forms also contain CYA or CH. You should be using liquid chlorine, aka bleach as it adds only chlorine and a trace amount of salt.
    How to chlorinate your pool
    If the Leslie's CYA test is right (unlikely) you will need to raise your FC to 35ppm and hold it there for the duration of the SLAM.
    Chlorine / CYA Chart
    Do you have a cartridge filter or sand filter?
    Are you willing to invest in your own proper test kit? It will be pretty hard to follow TFP advice and procedures without one.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,526
    These guys know what they're talking about. Follow their guidance and your pool will be sparking clean again, and at much less cost.
    The bottom line is that the shock products you have been using have raised your CYA level to the point that the free chlorine amount in your pool is no longer enough to effectively combat algae growth.
    Assuming your CYA is really 90, and that's a big assumption with pool store testing, the bare minimum level if FC you need to maintain to prevent algae is 7-8 ppm. And as Dom points out, now that you have algae, you'll need to maintain a level of 35 ppm for some period of time to kill it off again. One time "shock" will not suffice. You must maintain that level, the "M" in SLAM - Shock Level And Maintain.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
