Results 1 to 7 of 7
Thread: Cleaning up after being in a salt water pool?
    I've always spent time using fresh water to clean off pool toys, swim suits, etc. after being in a chlorine pool. Should this still be done after being in a salt water pool? Does the chlorine in the pool still have the same affect on clothes, toys, etc.?
    Thanks.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Cleaning up after being in a salt water pool?
    it is exactly the same, a salt water pool and chlorine pool have the same exact chlorine
    you don't have to rinse off but they may last a little longer
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Totally agree with Cowboy. Unless you have soft stone surrounding the pool. Then you might want to blast the splash zones with some freshwater to remove the salt.
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    Thanks for the replies.
    ITR, what do you mean by "Unless you have soft stone surrounding the pool. Then you might want to blast the splash zones with some freshwater to remove the salt."
    1. How would the soft stone surrounding the pool make a difference?
    2. What happens to the splash zones if the salt is not rinsed off?
    Thanks.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    There are some who speculate that salt can contribute to erosion of softer stones. I'm not sure it is true. There are lots of folks with salt and flagstone and no issues, like me. And there are folks with soft stones that are eroding but they don't have saltwater pools. I have some flagstone away from the pool in the yard that is eroding. So, the theory is that rinsing the salt off the stone might help. I don't buy it. But, it is just a little water and certainly won't hurt to rinse it off.
    JoyfulNoise's Avatar
    May 2015
    13,231
    Quote Originally Posted by pooldv View Post
    This is really a "Deep End" topic but salt damage is a real phenomenon. This PDF goes into some really gory scientific details but it demonstrates the complexity of the subject matter -
    https://www.researchgate.net/profile...13db000000.pdf
    Whether or not stone is damaged by salt is truly a complicated matter of not only the type of stone used but also the quality of the material as well as environmental conditions and what types of salts are present.
    So anyone who says that salt damage always occurs no matter what is just as wrong as the person who says it never happens. The answer lies in the middle and, unfortunately, there's no way to know before hand if it will happen and to what degree it will happen.
    As to the OP's question - I have a salt pool and I always throw towels and bathing suits in the laundry when we're done.
    Matt
    Thanks for all of the excellent info everyone!
