Thread: Grand Slam
    Jun 2016
    Midlothian, TX
    15
    Grand Slam
    Ok, so I just passed the TFP SLAM procedure and test this Tuesday (as in, two days ago). Now I get home from work today and my FC is 0 and my pool is milky. So far I've done a backwash and dumped some bleach in there. Having done that an hour ago, here are my current readings:
    CL = 5 ppm
    CA = 300 ppm
    Alk = 180
    CYA = 30
    ph = 8.2 (I had to add some tap water, which has a high ph. I'm adding acid to bring this down now)
    Salt = 2900
    I've also read that to bring the TA down that I need to lower the ph and then aerate it to raise the ph and then my TA will drop. I've been aerating for about a week now and TA stays exactly the same. So...I'm going to lower ph. But as far as the pool being milky and the FC dropping to 0, where do we go from here? I don't need to SLAM again, do I?
    9800 Gallon, In-Ground, Fiberglass, sand filter, Pump - Sta-Rite SuperMax 1.5 HP Model Number PHK2RA6F-103L, SWG - Optimum Pool Technologies Simple Cell, TF-100 Test Kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Grand Slam
    The question is why did your FC drop to zero?
    If the pool is milky, then yes, you likely do need to SLAM again. You must maintain proper FC to avoid algae getting started again. Chlorine is a consumable that must be replenished and tested for daily.
    Isolated Spa - 345 Gallons
    Major_in_MS's Avatar
    Jul 2016
    Florence, MS
    94
    Re: Grand Slam
    Have you been adding bleach daily since you ended your SLAM to maintain your recommended FC level? If so, there has to be a reason your FC dropped to zero so fast, and if the water is cloudy, then yes, you probably do need to SLAM again.
    24,200 gal., IG vinyl, 18' x 36' rectangular, average depth 5'. K-2006C
    Jandy SFTM22 sand filter, 1.65 HP PureLine VS Pump, Doheny's Discovery Robot.
    One skimmer, one main drain, two eyeball jets, and one return from the booster pump.
    One wife of 28 years (schoolteacher, first grade), four kids (ages 16,18,19, and 21).
    I work night shift (Pediatric RN) so most of my posts will be during the night.
