Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: Second SLAM
    Herwick's Avatar
    Apr 2016
    Ardmore, Ok
    49
    Second SLAM
    Now that my filter is up and running we have begun the SLAM process again. My numbers this morning and afternoon:
    FC: 8
    CC: 1.05
    PH: 7.2
    TA: 98
    CYA: 29
    FC: 15
    CC: .24
    PH: 7.2
    TA: 98
    CYA: 29
    My journey thus far:
    The first row is over the course of a month. I took a photo when there was a significant change.
    The second row is over a 2 week period.
    The third row is last week when we realized our filter was busted.
    The beginning picture of each row is the morning after the last picture in the previous row. We were keeping all numbers where they needed to be and suddenly it seemed a fight every minute of the day and then overnight it ended up being basically back to square one. So here's to hoping that with the filter fixed we will not have a repeat of before.
    Here it is on day 2 of the new SLAM! That was a lot of sand and dead algae. We cant see the bottom of the deep end just yet but we are hopeful it will only be a matter of days.
    1st time pool owner with 3 months of experience.
    25,000 gal, IG, vinyl, sand filter.
    ColorQ PRO 7 test kit
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Second SLAM
    Nice work. (I am so jealous of people with multiple skimmers)
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    triptyx's Avatar
    Apr 2016
    1,438
    Re: Second SLAM
    Stay the course! Keep us updated.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Herwick's Avatar
    Apr 2016
    Ardmore, Ok
    49
    Re: Second SLAM
    Now for my question. I was told to throw something that floats into the pool to check the circulation hence the wiffle balls floating around. If it turns out I don't have good circulation is that going to significantly effect the SLAM? Is there anything I can do to improve circulation? We can not preposition the jets so probably good idea to get ones we can. I have heard that you should position them to flow clockwise, counterclockwise, so they break the surface, so they don't. Very lost on that part. Suggestion will be greatly appreciated.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Second SLAM
    You said "jets", plural. With 2+ jets and 2 skimmers you should be fine. As long as the return is strong enough to at least push the water to the opposite side of the pool.
    Herwick's Avatar
    Apr 2016
    Ardmore, Ok
    49
    Re: Second SLAM
    We have 4 jets 2 at the stairs pointed right at each other and 2 in the deep end.
    There seems to be 3 dead spots that I am always having to skim leaves from. (The Xs) And the water seems to circulate the way of the arrows. The three balls have been going around in circles there in the shallow end. But they have only been in the pool for 3 hours. There is one hanging out in the far left just out of the picture and one that has been hanging out by the stairs for the last hour.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Second SLAM
    Yeah, circulation is the last thing you need to worry about
    Pool is looking good, can see the transition now!
    mulia's Avatar
    Jul 2011
    NE Ohio
    100
    Re: Second SLAM
    I don't have an inground pool, but I would direct all the eyeballs counterclockwise that should creat a strong flow around the pool into the 2 skimmers.
    INTEX AGP 15'x 48", 4440 gals.,INTEX 2650 gph pump w/ 16" sand filter, Hayward widemouth skimmer,INTEX SWG-CS8110, 1 1/2" hard plumbed PVC, Lil' Shark vac w/ leaf canister, INTEX floating LED pool light, solar cover with polaris solar reel, Access pool steps 200600T, TF 100 test kit, "The Slime Bag" x-tra polishing 18" x 30"
    Herwick's Avatar
    Apr 2016
    Ardmore, Ok
    49
    Re: Second SLAM
    Quote Originally Posted by Mr Bruce View Post
    Thanks, I wanted to double check with someone as I was told the balls should eventually end up in the skimmers, them going in a circle for 3 hours was starting to worry us. I didn't want to end up back at the beginning because all the water wasn't being properly circulated and filtered. Its been a long couple months working on this.
    Herwick's Avatar
    Apr 2016
    Ardmore, Ok
    49
    Re: Second SLAM
    Day 3: This morning's numbers:
    FC: 13
    CC: .04
    PH: 7.2
    TA: 76
    CYA: 35
    I am waiting for a CC 0 before doing the overnight loss test. My question is if CC is 0 and I pass the overnight loss test but the water is still cloudy do I have to keep FC at SLAM levels while the filter is doing its work? It seems that if I keep it in normal range that it should keep everything dead while filtering out, right? I somehow figured it would clear up before CC ended up at 0, doesn't look that way though.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Second SLAM
    YEs.. the 3 criteria is Clear water, CC <.5 and less than 1 ppm FC loss... Keep at it... you don't want that stuff back in your pool right?
    Make sure you check your filter pressure too and backwash to keep it cleanish.
    how did you come up with .04 cc?
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Herwick's Avatar
    Apr 2016
    Ardmore, Ok
    49
    Re: Second SLAM
    Quote Originally Posted by cj3737 View Post
    FC - TC = CC my test kit is digital so math came up with .04.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Second SLAM
    Ahh ok...
    What CYA are you targeting?
    13500 gal
    Herwick's Avatar
    Apr 2016
    Ardmore, Ok
    49
    Re: Second SLAM
    Ahh ok...
    Going for 30. Yesterday I got a reading of 25, in the later afternoon and evening, since I hadn't needed to add stabilizer for a couple weeks I figured I'd put some more in and overnight it shot up to 35.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Second SLAM
    Target 40 CYA Shock level 16 then... best to err on the side of caution... More FC is better than less FC.
    Hows your circulation working out?
    Something about your pics is still troubling me...
    13500 gal
    Herwick's Avatar
    Apr 2016
    Ardmore, Ok
    49
    Re: Second SLAM
    Overnight only 2 of the balls ended up in the skimmer. The other 3 were still going in circles where they are in the picture. Now obviously I can not tell if they are the exact same balls that stayed there all day and I realized that this morning but still I don't think it bodes well.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Second SLAM
    I have a round pool with 1 jet so circulation is easy... Mr Bruce said earlier it doesn't matter as long as it gets to the other side of the pool...Mulia says counter clockwise which I agree with more so... You don't have the ability to move the direction of your jets do you?
    13500 gal
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Second SLAM
    I cannot find a ColorQ 700 online. That isn't one of the recommended kits as far as I can tell. Digital tests usually need frequent calibration.
    If your pool is forming eddies it is circulating fine. I have a feeling it just needs a good dose of POP (and probably another test kit )
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Second SLAM
    Something like this maybe..
    https://www.amazon.com/LaMotte-2064-.../dp/B003MYCUYK
    13500 gal
  20. Back To Top    #20
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Second SLAM
    Seeing eddys raises a flag to me... Im still new in the process and don't get them in my roundy, but If I think if how they are formed in a flowing body of water (rivers and such), the water eventually makes it out of the calm sections but I can see it being a place where introduced chemicals may pool. The water may not turn over in those areas...unless they were right in front of the skimmers...
    If you see it differently , please explain ... I would love to learn something new today as my clean and clear pool is now boringly predictable..
    13500 gal
