Results 1 to 8 of 8
Thread: New pool coming
    Jul 2016
    Milton
    18
    New pool coming
    Hi, I'll be assembling our first pool this weekend and had a question for y'all. Should I add my chemicals as I fill the pool or should I wait until it's full and see what my numbers will be. I'll be filling it out of our well and I do know that water is on the acidic side. (5.9 I think). Thanks for any advice. This looks like a great site with a ton of information. I have ordered my test kit and I belive the pool is ~19K gallons.
    Justin N.W. Florida
    27' AGP 54" Depth K-2006 test kit
    Hayward super pump 1H.P.
    Hayward Star Clear C12002
    Jun 2014
    15,093
    Re: New pool coming
    Hello and welcome to TFP! Generally you can just wait until the water reaches the skimmer opening so that you can circulate water. But more than anything, your well water would concern us. You might want to have it tested for metals - specifically iron. Test before going into the pool. Iron is very common in well water. If you have it, do some searching here at TFP about pre-filters. If you do have iron content, the more you can physically pre-filter out before it goes in the pool the better. After that, you may need to read the TFP Pool School - Metals in the Water and Metal Stains page.
    Also, make sure to read our Pool School page and do not rely on that in-line chlorinator for daily sanitation. Tabs add too much CYA to water when used continuously. Great to see you've already ordered a recommended test kit. Please make sure to add it to your signature as well for us. Have a great day!
    Jul 2016
    Milton
    18
    Re: New pool coming
    Thanks, I'll check for iron content tomorrow. I haven't hooked up the auto chlorinated yet, would you recommend not using it? And I guess that would mean a former of liquid chlorine is better?
    Justin N.W. Florida
    Jul 2016
    Milton
    18
    Re: New pool coming
    Bought a kit from lowes. Iron content was around .3ppm and copper was 0. That makes me feel better about getting started.
    Justin N.W. Florida
    Jun 2014
    15,093
    Re: New pool coming
    Good morning! Yes, liquid chlorine is generally best to use on a daily basis. Tabs are okay only for short-time use (i.e. vacation). Are you in Milton, FL? You can check locally, but any regular bleach will do - generic is fine. Just never use splashless or scented bleaches. One thing for sure, new water won't have any stabilizer (CYA) in it, so you'll want to add some. For summer, if your pool is full sun, I would advise a target CYA of about 40-50. You can start the CYA as soon as the water is full.
    To increase CYA via granular stabilizer, place the required amount as calculated by the Poolmath calculator into a white sock and place in the poolside skimmer basket. For those concerned about suction flow to the pump, suspending the sock near a return jet or from a floating device will also suffice. Best never to allow undissolved granules to rest directly against the pool surface. Squeeze the sock periodically to help it dissipate. Once dissolved, consider your CYA adjusted to that programmed (target) level. CYA test readings should show a rise in 24-48 hours, however some pools may experience a longer delay to fully register. Best to confirm final CYA in about 5-7 days before adding any more stabilizer/conditioner.
    After that, test FC. It will probably be low. On day one increase FC to about 3 ppm (with bleach), then once the stabilizer is dissolved and in the water you can increase FC to about 5 ppm. I wouldn't let FC drop below 4 after that in the summer heat. When in doubt, always refer to the Chlorine/CYA Chart (link below) to keep algae away.
    Next is pH to make sure it's in the 7.5-7.8 range.
    We can look at TA later, and CH shouldn't really apply to you with a vinyl pool. But all the info you need is in my sig below. It's good your iron reading is below .4. Hopefully you won't see any reaction between the chlorine and metals once combined. Still, you can always do some pre-filtering and/or place a few paper towels in your skimmer early-on to try and catch any iron residue that might be floating around. If the water starts to change to a tea brown or clear, emerald green, let us know.
    Jul 2016
    Milton
    18
    Re: New pool coming
    Thanks for the help. Yes I'm in Milton, FL actually a little north of there.
    The only other question I have is if I'm going to use borates, can I use that to raise the pH at the same time I'm reaching my 50 ppm. Or should I get the water chemistry stabilized first and and borax later?
    Jun 2014
    15,093
    Re: New pool coming
    I would get your basic chemistry in order first, make sure things are going well, then look at your options for borates.
    Jul 2016
    Milton
    18
    Re: New pool coming
    Pool is up and almost full!!!
    Poured a pad for the pump and filter, should be able to have it all hooked up this afternoon.
    Justin N.W. Florida
