Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Tested water with new Taylor K-2006- help with results
    Daisy08's Avatar
    Sep 2014
    Nazareth PA
    32
    I recently purchased the Taylor K-2006 test as I do not entirely trust the kids at the PS reading my water. I am new to owning a pool as of 2015 so I still feel unsure of numbers and where I truly need to be. I have read pool school but sometimes all the info is overwhelming and is easier to ask a question.
    I used a YouTube to figure how how to use the Taylor test kit and I was hoping to have 2 questions answered
    1. Are my numbers normal/good or do I need to make adjustments?
    2. The test did not have a Total Chlorine test- I just tested for FC and CC. Did I miss the TC or doesn't this test have it? Should I be testing for TC?
    My water is clear, looks good, however, I do feel like it is a little slippery. So hard to tell if that's normal or is it the start of an issue. Maybe it's just salt water that makes the liner slippery (smoother water)? And how would I decipher if I am on the verge of an outbreak? Ok so that is 3 questions I guess!
    FC- 5 to 5.2 (giving myself room for error)
    CC- 1 to 1.6 " "
    PH- 7.8
    Alkalinity- 90-100
    Calcium Hardness- 60
    CYA 50
    Salt 3200
    18x36 IG Vinyl liner Pool. 25,000 gal. Installed June 2015. Salt Water Hayward Aquarite AQR9. DE filter- Hayward DE3620. Hayward Super Pump variable speed. Taylor K2006.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    Re: Tested water with new Taylor K-2006- help with results
    That CC is troubling. I would start a SLAM right away. Lower the pH to 7.2 first.
    e: Total chlorine is FC + CC. Don't worry about posting TC
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    mulia's Avatar
    Jul 2011
    NE Ohio
    100
    total chlorine TC is free chlorine FC + combined chloromines CC
    FC + CC = TC
    so 6 ppm tc is what you have
    Normally, SWG cya recommendation is 60 to 80
    Your cc is high and may indicate a SLAM in your future, but an expert will chime in soon, I'm sure
    INTEX AGP 15'x 48", 4440 gals.,INTEX 2650 gph pump w/ 16" sand filter, Hayward widemouth skimmer,INTEX SWG-CS8110, 1 1/2" hard plumbed PVC, Lil' Shark vac w/ leaf canister, INTEX floating LED pool light, solar cover with polaris solar reel, Access pool steps 200600T, TF 100 test kit, "The Slime Bag" x-tra polishing 18" x 30"
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Fc is a little low for a CYA of 50 Should be closer to 6 or slightly above
    PH is on the high end but still ok
    CC is way up which is why your pool feels slippery.. there is something in the water
    Sounds like some brushing and a good slam is in your future
    TC is a by-product of FC+CC. Don't be worried about TC. FC and CC is key
    Follow the SLAM procedures word for word and you will be set up for success
    http://www.troublefreepool.com/conte...tain-shockingl
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Daisy08's Avatar
    Sep 2014
    Nazareth PA
    32
    Thanks for responses. I did read SLAM but I still don't understand the steps needed. I am not sure how to get my readings to where they need to be.
    So far, I understand that I need to lower PH. If I add the MA, how long do I have to wait to SLAM after adding MA?
    Then after lowering PH to 7.2-7.5, what do I do to SLAM for SWG to get it to "shock level?" And then am I testing frequently for FC or CC or both as I am shocking the pool? Sorry, clearly I am a newbie. Thanks for the help
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    For the duration of the SLAM you turn off your SWG and just manually add chlorine to get to the SLAM level and stay there as best as possible through the day. Yep, test, add, test add to stay at whatever your SLAM level is (20 for CYA of 50)
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Quote Originally Posted by Daisy08 View Post
    Like MrB says... turn off your SWG for the duration...
    Add the required amount of MA to bring your PH down... Wait about 30 min for the acid to disperse then blast up your FC level. Since your CC is high, test every hour or 2 to maintain your FC shock level. Once the gunk in the water starts to die off and filter out, your cc will start to come down and your FC will not drop as fast. When it gets down to .5 CC you can think about doing the OCLT but not until then. Keep a good eye on your water clarity too. As the algae dies off it may cloud up the water so keep brushing during the slam.
    Once your water is clear, CC is less than .5 you can start the OCLT
    http://www.troublefreepool.com/conte...loss-test-oclt
    If you post your results during the slam, some one on here may be able to guide you if any questions arise
    13500 gal
    Daisy08's Avatar
    Sep 2014
    Nazareth PA
    32
    Ok so based on my current numbers, I should get my shock level to FC of 19.8? Chlorine/CYA Chart
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    That's the nerdy version. Use the one for simpler minds like mine. Pool School - Chlorine / CYA Chart
    I have that taped to the inside cabinet where I test, and look at it often.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Call it 20... Make sure you drop the ph first
    13500 gal
    Daisy08's Avatar
    Sep 2014
    Nazareth PA
    32
    Right, D'oh Mr Bruce said 20.
    When in the process do I turn the SWG back on?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    After the SLAM is finished
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    +1
    13500 gal
    Daisy08's Avatar
    Sep 2014
    Nazareth PA
    32
    Thanks for all the responses. I do have one last question- what is the reasoning for turning off SWG when SLAMing?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    Among other things, it muddies the water. It's better to know exactly how much chlorine you are adding and losing without the SWG "helping". Since the SWG runs when the pump runs, and the pump runs 24/7 during a SLAM, how do you know when you passed an OCLT
    Daisy08's Avatar
    Sep 2014
    Nazareth PA
    32
    Ok thank you. Going to read OCLT again. Sooo much information swirling through my brain!! I will catch on soon enough
    Daisy08's Avatar
    Sep 2014
    Nazareth PA
    32
    Oh my gosh, I thought of one last thing. What if I have my SWG chlorine output up too high thusly making my FC high? I had it on 85-90%. Should I back off of the percentage before I SLAM to see if that is why my FC and CC is on the high side? Won't SLAMing just make the FC and CC higher?
    AND I went to pool store to have them check my water and THEIR results are:
    FC 4
    TC 4
    CYA 80
    PH 8
    TA 110
    CH 110
    Salt 3200
    So their results conflict with mine. UGHHHH!! I did just add some dry acid to pool to lower PH.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Stay away from the pool store.... Trust your results. they may have used tap water for all you know...
    Just shut off the SWG now and use bleach until your slam is over...You are right on the edge.
    FC is what you are adding with the SWG and bleach.. CC is what happens when the bleach kills the contaminants
    And run your pump the entire slam as well...Itll help take out microscopic debris
    13500 gal
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Higher FC is better than lower FC. I wouldn't mess with the settings until after the slam... you will have a sparkling pool and room to play with it once your clear and sanitary. If you FC gets too low, you run the risk of things growing again.. My target is 6 but I dabble in the 6-8 range when adding bleach. FC will always come down until you add more
    13500 gal
  20. Back To Top    #20
    Daisy08's Avatar
    Sep 2014
    Nazareth PA
    32
    Quote Originally Posted by cj3737 View Post
    Ok so I went back and re-did some of the tests just to take out user error since it had been the first time using. Here is what I got consistently:
    FC 6
    CC 0 (no change in color)
    TC 6
    PH 7.6 (just added 2 lbs of dry acid in 1 hour intervals- 1 pd per hour)
    Alkalinity- 90
    CYA 40
    Should I still SLAM. THank you thank you for responding. I know I am a PITA
