Results 1 to 11 of 11
Thread: white spots on vinyl liner
    Jun 2015
    Albion Indiana
    6
    Exclamation white spots on vinyl liner
    a gray line appeared only on one end of the shallow end, this line started to disappear but now it is starting to turn white? it is above the water line.IMG_0986[1].jpg can anyone tell me what this is and how to get rid of it?IMG_0985[1].jpg
    PH 7.6
    FC 3
    CC 1
    TC 4
    CH 350
    TA 80
    CYA 60
    salt 4000ppm
    20'x40' inground concrete and vinyl 32,900 gallons, Aqua Comfort Heat Pump, Pentair 1.0 hp pump two speed, Pentair Sand Dollar filter SD80 75gpm, Pentair Intellicholor Salt Chlorine Generator, automatic cover, pool installed September 2014
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,317
    Re: white spots on vinyl liner
    Is it rough or smooth?
    Dolphin E10 Cleaning Robot.
    Jun 2015
    Albion Indiana
    6
    it feels rough
    Jun 2015
    Albion Indiana
    6
    it is rough
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Sounds like calcium scale. Enter all your test results in Pool math and it will calculate your CSI. Keep it negative -0.3 to 0. Tweak PH and/or TA.
    More here, Pool School - Calcium Scaling
    Jun 2015
    Albion Indiana
    6
    would Calcium scaling remove the color from the liner?
    May 2016
    Troy IL
    476
    Does calcium scale happen on vinyl? I was under the impression it didn't stick to vinyl.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    DFW, TX
    24,468
    I don't know if scale can remove color, it doesn't seem like it should. Yes, scale can definitely stick to a vinyl liner.
    Jun 2015
    Albion Indiana
    6
    what can i use to try and remove it?
    DFW, TX
    24,468
    There a couple of options in the link I provided. You can also put dry acid in a sock for isolated spots.
    Jun 2015
    Albion Indiana
    6
    my pool installer thinks it is a defect in the liner itself, which has caused it to loss its clear finish over the print. sending pics to the manufacturer to see if warranty will cover it. pool is not yet 2 years old.
