Thread: Programming a Intelliflo VS pump
    Jul 2016
    Atlanta Georgia
    2
    Just replaced my old single speed pump with an Intelliflo VS pump. I need to program it to run efficiently and effectively. This pump runs the pool only as my cleaner is a Dolphin M4. The pump sits about 3' above the level of the pool.
    Pool: In ground 28,00 Gallons 18x36 vinyl 8' deep end with 2 skimmers and 2 drains. Pool Pump: Pentair Intelliflo Variable Speed
    Chlorine Generator: Goldline Salt System. Pool Filter: Jandy CL340 Cartridge. Heater: Jandy Lite. Pool Cleaner: Dolphin M4. Automatic Pool Cover: Coverstar
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Programming a Intelliflo VS pump
    Check out this article here: Pool School - Determine Pump Run Time
    With an SWG, run the pump for as short of a time period, or time periods split to do so, to achieve sufficient sanitation using your SWG. Higher SWG output for shorter intervals is the most economical.
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    Mar 2015
    Chico
    27
    I've got a 12k gallon pool and my pump is about 1-2' above the level. The installer said these pumps can pull quite a bit of head so I don't expect much difference between my setup and yours? Assuming that's ok, here's how mine is set up:
    Priming >
    Priming time: 0
    Priming speed: 2200
    Assign speeds >
    Freeze: 1000
    Pool: 1800
    Cleaner: 2250
    Waterfall: 1700
    Hope that helps!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Welcome to TFP!
    Find the lowest speed that the SWG won't give a flow error and run it a couple 100 more. Mine was 900 rpm so I run mine at 1100 rpm for skimming filtering and making chlorine.
    Jul 2016
    Atlanta Georgia
    2
    Quote Originally Posted by pooldv View Post
    Welcome to TFP!
    Thank you.
