Thread: Fiber light strip repair
    Jul 2014
    LaGrange, KY
    7
    Hi,
    We have a fiberglass pool with a (what I believe) is a fiber light strip installed around the top inside edge of the pool. It has been screwed in and over the years, the water and salt has caused the screws to rust and erode, so the strip is pulling away from the pool wall. Has anyone else had this issue? This pool is new to us, and we are wary of adding more screw holes to the fiberglass. The strip works fine, it just doesn't look so good.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Fiber light strip repair
    Could you post some pictures both up close showing the screw holes and some further away with about half the pool.
    You may want to open a photobucket account post there and link the pictures.
    Jul 2014
    LaGrange, KY
    7
    I hope these links work!
    Last edited by JVTrain; 07-15-2016 at 11:49 AM. Reason: Moderator edit to fix img links.
    Apr 2013
    Sacramento, CA
    2,769
    Search fiber optics swimming pool perimeter lighting at Inyo pools. I don't think it's the same but I suspect it's no longer made.
