Thread: Green pool
    Jul 2016
    Iowa Park
    3
    Green pool
    I apologize if this is too elementary a question, but I have been reading posts all morning, and am still confused.
    We have an 1800 gal AG Intex pool w/ the Intex Salt Water unit, and cartridge filter. While waiting for a replacement part on the Salt Water unit, the water turned green, and since getting the replacement part and boosting, the pool is still green.
    Using the test strips that came w/ the unit:
    FC: 1
    pH: 6.2
    TA: 40
    CH: 0
    hth Salt test strips: 2830 ppm
    Thank you for your time, and any assistance you can give,
    Beth
    Iowa Park, TX
    Aug 2013
    Oklahoma City, OK
    140
    Re: Green pool
    What test kit are you using? What is your CYA level?
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    Jul 2016
    Iowa Park
    3
    Re: Green pool
    Quote Originally Posted by Tanner M View Post
    Intex 4 Way Test Strips Dip and Read
    Jun 2014
    15,255
    Re: Green pool
    Hi Beth and welcome to TFP! I have a couple questions just to be sure of some things:
    - Is your pool gallon size actually 1,800 gallons?
    - If it is only 1,800 gallons, have you visited the TFP Pool School - Guide for Seasonal/Temporary Pools page? It outlines brief instructions for small pools that should make things much easier for you.
    We'll look for your reply and try to give you some more direction to get your pool clear again. Nice to have you with us.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Green pool
    Ok. First of all, welcome!!
    Second of all you really need to get a proper test kit. I highly recommend this one: TFTestkits.net as will most others on this site.
    1800 gallons is a small pool, which right now is to your advantage. There is a SLAM process that you need to follow, and it can be time-consuming. If your pool is actually 1800 gallons I would just drain and refill it. Are you on town water or well water?
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jul 2016
    Iowa Park
    3
    Re: Green pool
    Thank you so much for your time....yes, it is actually 1,800 gallons....it's a little thing. We do have the option of draining the pool, but we would just rather not, as our area has recently dealt w/ severe drought. Our lakes did fill, but we are still so water conscious that we just hate to do it. That being said, we will drain it if that's the best option; we just prefer to conserve. It's hard to waste so much, when our whole family and farm is accustomed to making it on 3,500 gal/mo. I will look into getting the recommended test kit so I can get all the appropriate levels. We are on co-op water.
    Thanks again,
    Beth
