Thread: CYA during a SLAM
    May 2016
    Baker/Florida
    9
    CYA during a SLAM
    I've started the SLAM process. My question is do I need to check my CYA levels DURING the SLAM and adjust chlorine accordingly or just stay concerned about keeping pool at shock level? I already checked it before starting the SLAM along with my other levels and adjusted where needed.
    Thanks!
    21k gal, AG vinyl Radiant pool, 1.5 hp whisperflo pump, 24" sand filter, inline chlorinator,
    Installed 2012, no well water or water restrictions.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: CYA during a SLAM
    You do not need to recheck the CYA unless you have a large loss of water and a refill. Basically, you just check FC and CC during a SLAM, as the PH is inaccurate when the FC is over 10. After you pass all three criteria for ending your SLAM you can recheck everything after the FC comes down.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Unless you have big water exchanges (lots of vacuuming to waste, for instance) your CYA will stay the same so no need to test often.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2016
    Baker/Florida
    9
    Great! Thank you! Another question, when I vacuum, should I be vacuuming on the waste cycle to avoid the water exchange? Will the dead algae hurt my filter?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    It should not hurt it, but it may make you need to backwash sooner. You should backwash when your psi rises 25% over the "clean" pressure.
