Results 1 to 7 of 7
Thread: Doing TFP right or not?
    Jul 2016
    Saint Joseph, MO
    45
    My pool has been crystal clear for several days after completing SLAM and paying close attention to TFP recommendations.
    CYA 40
    FC 9.5
    CC 0.5
    PH 7.6
    TA 150
    CH 130
    IF these numbers stay similar, pump running half days and backwashed as needed, and FC maintained above 3 (probably err the high side), will it really just stay clear?
    CHAD
    24' Above Ground 46.5" deep, 13,147 gal
    Hayward E-Series 25GPM/m2
    Sand 200 lbs
    Hayward Power-Flo LX 1.5hp
    Taylor K2006
    Mar 2015
    South Texas
    411
    Re: Doing TFP right or not?
    I know it's hard to believe, right? But, yes, it will be a Trouble Free Pool! That's kind of the point!
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Don't forget to brush regularly!
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    YEs it will.. even if you forget a day or 2 here and there.... I hadn't tested my water in 3 days (life got in the way) and its still crystal clear....
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Jul 2016
    Saint Joseph, MO
    45
    Quote Originally Posted by nlindelldc View Post
    Brilliant! Figuratively and literally!
    Quote Originally Posted by PAGirl View Post
    Yes! Every evening before adding a bit of chlorine. Also, not neglecting the ladder and the holes in the steps.
    Thanks again!!!
    CHAD
    Sand 200 lbs
    Taylor K2006
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Yes! My pool has been crystal clear every day for 4 years. No draining, no shocking and most of all no missed swim days! We swim every day that we want to swim, no exceptions. Even when I got a little lazy last summer and let the FC drop to minimum and got some algae the water stayed clear and we did a quick swim-n-SLAM.
    Apr 2013
    Akron, NY
    40
    4th season for me, has always been crystal clear. Quick test every day and feed it some chlorine. Treat it like a pet. Feed it every day to keep happy and it won't bite you!
    24 foot 54 inch AGP, 14.5k gallons, 1hp pump, 120 sq foot cartridge filter
