Results 1 to 20 of 20
Thread: Raising FC
    Jun 2016
    Manteo north carolina
    50
    Raising FC
    Fc is 1
    cc is 2
    cya 70 -can't test until Friday, one week after I added Cya but that was my target
    Need to get my Fc to 5. I have a Swg should I add liquid bleach to raise it?
    Above ground intex 24x 52 Swg with sand filter pump. Well water. New started the end of May. 11,600 gallons. Test kit TF100
    Jun 2014
    15,027
    Re: Raising FC
    Some questions for you before you do anything else:
    - How did you add the stabilizer?
    - When did you add the stabilizer and why do you think you have to wait until Friday?
    - How does your water look (hazy, green, perfectly clear?)
    I ask because your CC is elevated which is a warning sign you may need to SLAM first. Best to do that at a lower CYA level before popping it up for your SWG. But yes, you can always use regular bleach to help augment your SWG.
    Jun 2016
    50
    Re: Raising FC
    Perfectly clear. I added with a sock in front of my return. I thought you had to wait a week to test for cya levels.
    Last Friday is when I added the cya.
    Jun 2014
    15,027
    Re: Raising FC
    The week rule was revised this year after some extensive testing. So if the sock was all dissolved last Friday, you should be able to test now. We estimate most CYA should be testable in 24-48 hours. So good - clear water. Nice. Then yes, definitely add some bleach to get your FC up until you get the SWG dialed-in the way you want it. Hope that helps.
    Jun 2016
    50
    Re: Raising FC
    Yes that helps. Thank you. You all here at TFP always do help me and many others.
    Jun 2016
    50
    Re: Raising FC
    Do I still run my Swg when I add the bleach?
    Jun 2014
    15,027
    Re: Raising FC
    Sure. You can have it going so you can continuously adjust percentage and/or run time to get the FC production you need. At some point, you'll get it the way you want it so you can back-off of the bleach.
    Jun 2016
    50
    Re: Raising FC
    Retested this morning after adding liquid chlorinater Fc-5, cc-1. Should I be concerned about cc?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Raising FC
    If the water is crystal clear, I don't think you need to go into a full on SLAM. I'd raise the FC up a little over target and let that work all day. Check it again late this afternoon, we should be sunny today so I have a feeling that CC should burn off and you should be good.
    If you want to be 100% sure, you could do an OCLT tonight (with the SWG off) to see where you are.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Raising FC
    If it were me, I would bump the FC up just a bit to help drop the CC and test again in a little while. ITs already come down a bit so a little more chlorine will help take care of whatever is causing your elevated CC level.
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Jun 2016
    50
    Re: Raising FC
    To raise my fc up higher could you recommend a number please?
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Raising FC
    I would go up to 9 so you can still get a good PH reading... FC will migrate back down over time. It that doesnt take care of it, it may be time to slam
    then do the oclt tonight
    13500 gal
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Raising FC
    Maximum FC loss for a hot sunny summer day like we should have today would be <= 4. If you are at 5 this morning, I would add 1/2 gallon of 10% (that's what I get in Pool Math for 11.6k, rounding up. Please check behind me and adjust for your bleach strength) to get to 9. If you were below 5 late this afternoon, that would be indicative of a problem.
    e: wow
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Raising FC
    Take a look at your pool volume too... 24' x 54" deep shows 15,200 gal
    I have a 24' x 48" that holds 13500
    13500 gal
    Jun 2016
    50
    Re: Raising FC
    I probably need to do the OCLT tonight. Since I never slammed my pool when I started it. But I did add liquid chlorine to bring it up to a 9.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Raising FC
    Hopefully it passes...Keep us posted!
    13500 gal
    Jun 2016
    50
    Re: Raising FC
    I did the OCLT test last night my fc was 7, cc 1. This morning fc3, cc 1. Time to slam. My ph is 7.5. Going to retest my cya 3 days ago it was about 60. When I slam do I leave my Swg off?
    Jun 2014
    15,027
    Re: Raising FC
    Yes, it's usually best to leave the SWG off during a SLAM and just maintain the higher FC level with regular bleach.
    Jun 2016
    50
    Re: Raising FC
    I am waiting till this late this afternoon to slam. I will test FC again and go from there.
  20. Back To Top    #20
    Jun 2016
    50
    Re: Raising FC
    Once I get my FC up to 24, how often do I need to test?
