Thread: Pool pump plumbing question
    markuszoom5's Avatar
    Jul 2014
    Liverpool NY
    121
    My Union nut that connects to the diverter valve has finally cracked. I was able to remove the pipe from the pump. I think the pump just does not fit flush on the diverter valve receiving end. Is it ok to have an elbow or two plumbed to the intake port of pump or does it have to be a straight pipe running into the pump from the diverter valve? Maybe I should use flexible tubing by screwing a nipple into the intake port and a if they have a nipple that attaches to the diverter valve. I have to get it fixed tomorrow so the water can circulate.
    Circa 20,000 gal IGP, 12 years old, Hayward SP2607X10, 1 hp single speed pump, Hayward S244T Sand filter, vinyl liner, using Aquacheck test strips and Taylor K-2006 Test Kit, 1 skimmer, 1 bottom drain, 2 jets (near stairs and on the opposite deep end)
    Jun 2014
    15,233
    Re: Pool pump plumbing question
    Hello Mark. I see you haven't gotten any bites on your thread yet. It's been a couple days so you might already have this completed. But in general .. yes, the ideal way would be to have about 6 " or so of straight pipe going to your intake. Flexible tubing can be a little tricky and unpredictable, so I'd be careful with that as well. If you still need help, let us know or perhaps post a pic of your set-up so we can see it better. Maybe some others will reply after bumping this thread up a bit.
    Jul 2014
    Liverpool NY
    121
    Yea, thanks..I was going to 1/2 - a.. it until the weekend and then redo it but I ended up going to buy all the parts from the pool store and they guy said he would do it for $80 if I buy all the stuff from them and give them the old pump. I honestly did not need the old pump anyway since it burned out. So I got a good deal on it all $668 all together and new valves and plumbing. I had no time to do it myself unfortunately.
    Jun 2014
    15,233
    Glad it worked-out for you.
