Thread: Raypak heater issue
    Jul 2016
    Brecksville, OH
    2
    Raypak heater issue
    Hello all, my name is Mike and first time I am posting a question. I have an above ground pool with a Raypak 156a 150000 BTU heater. Only 1 year old. Has been working well but yesterday I started getting an ignition failure. The spark starts, it will light but seems late (meaning you can hear it lite about a second after the spark stops), then goes out immediately then back to spark. It seems like there is a pause between spark, late lite, and it does not register that it is been lit and turns gas off and starts ignition cycle again. Also, seems like sometimes it takes 2-3 sparks to light briefly then off again. I hope I am explaining to where you all understand. I thank you greatly for any ideas or solutions.
    ps0303's Avatar
    Jul 2011
    FL
    3,710
    Re: Raypak heater issue
    It could be a few things. Natural or propane gas? If propane, make sure your tank is full. Next, check inside and make sure everything seems ok. Make sure no mice have made any home inside the unit or chewed any wires.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    Jul 2016
    Brecksville, OH
    2
    Quote Originally Posted by ps0303 View Post
    Thank you for your response. It is natural gas. I did take the burner out to make sure the igniter was clean. Not sure how it is supposed to look but I noticed that the outer ends of the burner was corroded a little and the ends of several of the individual cross burners were open. Looked like they should be sealed. I will have to look at a new one to see the difference.
    mulia's Avatar
    Jul 2011
    NE Ohio
    100
    Hi neighbor! You could call Dominion. They do not repair appliances, but could make sure your gas to the heater is sufficient & the service is free.
    INTEX AGP 15'x 48", 4440 gals.,INTEX 2650 gph pump w/ 16" sand filter, Hayward widemouth skimmer,INTEX SWG-CS8110, 1 1/2" hard plumbed PVC, Lil' Shark vac w/ leaf canister, INTEX floating LED pool light, solar cover with polaris solar reel, Access pool steps 200600T, TF 100 test kit, "The Slime Bag" x-tra polishing 18" x 30"
    ps0303's Avatar
    Jul 2011
    FL
    3,710
    The ends of the burners that face the back of the heater should be closed. Looks like they are crimped or folded over, but they should be closed off. If that end is open you have an issue.
    Paul
