Results 1 to 8 of 8
Thread: Intex sand filter drain/backwash fitting size question
    Jul 2016
    Boaz, KY
    17
    Just curious, on the Intex sand filter pumps, is the drain/backwash outlet the same non standard thread as the pool inlet and outlet fittings?
    David
    Jun 2015
    Stockholm, Sweden
    250
    Re: Intex sand filter drain/backwash fitting size question
    Yes, all the connections on the filter and pump are the same Intex thread.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jun 2016
    Celina, TX
    34
    And so is the actual drain on the bottom edge of the pool. That ain't no standard garden hose connection...... I had to drain some water to get rid of a hi salt issue. I went to connect a garden hose to the drain plug..... no can do.... AArrgh..... I don't want to drain water right next to the pool, so I used the backwash & rinse settings on the sand filter/pump. Now this worked fine for what I was doing, but when it comes time to drain the water down past all the plumbing for winter storage.....
    Bill (aka CR172) 16' x 48" (5300 gal) Intex Ultra Frame AGP, 2150 GPH 14" Intex sand filter/pump, Intex CS7110 SWG, Intex under water magnetic pool light, Hayward SP1091LX skimmer, Confer Roll guard safety ladder, TF-100 test kit w/ AquaCheck salt test strips.
    Jun 2015
    Stockholm, Sweden
    250
    Best way to drain for winter is to buy a cheap submersible drainpump. Or pump to waste down to outlet level and siphon the last few inches with a hose over the side.
    Jul 2016
    Boaz, KY
    17
    Thanks for the info! The reason I asked, I'm trying to find a source of the Intex collar nuts, without having to buy hoses, or other accessories, just to scavenge them. I was looking at the drain caps, as a possible source, if the centers were cut out.
    David
    KazzyK810's Avatar
    Jul 2016
    Davison, Michigan
    75
    Quote Originally Posted by CR172 View Post
    I use a sump pump. It's my backup in case my house sump pump goes out, but I also used it to drain down my in ground pool at my last home, and I use it to drain down my Intex pool for winter storage. I have a long flexible hose attached to it, to direct the water away from my house & pool. Works great! And works quickly!
    Karan - 18 ft round x 48" high - Intex ultra-frame AGP, Intex 3/4 hp pump with 14" sand filter (SF70110), Hayward 900 Wanda the Whale cleaner, Intex LED water fountain.
    18ft Round Intex Ultra Frame in The Mitten
    Jun 2015
    Stockholm, Sweden
    250
    Quote Originally Posted by astrowolf67 View Post
    David
    you can buy all Intex parts as spares here: Replacement Parts - Above Ground Pools - Store - Intex
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    I find this observation quite interesting in the evolution of the Intex pool. I bought my pool last year and it has garden hose sized drains on it. I bet a pool with 40mm drains would empty out fairly quickly!
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
