Results 1 to 9 of 9
Thread: New & first pool
    Jul 2016
    Joshua, TX
    4
    New & first pool
    Hi,
    After studying this forum for a couple of weeks I was convinced to get a pool since y'all make the maintenance sound so easy.
    Starting out with a 12x24 above ground.
    It will be delivered tomorrow, I have already leveled the sight, put concrete blocks for legs and have sand down for cushion under pool, I plan on setting up tomorrow and filling Friday/Saturday with "city" water.
    I have a TF100 test kit that was delivered today.
    I plan on starting with 210 lbs of pool salt from what I have read so far.
    Is there any other chemicals I should start with before I test or should I wait till the pool is full?
    Would there be any advantage to testing the water right out of the tap or filling my dogs pool & testing the water after a period of time?
    Clint
    12' x 24' x 52" AG Intex 8,403 gallons, Krystal Clear Sand Filter pump and Saltwater System, TF100 test kit, Rural city water Johnson County TX----installed 7/15/2016
    Jun 2014
    15,274
    Re: New & first pool
    Hello Clint and welcome to TFP! Having the TF-100 was a great decision. Besides the salt, you'll need to add stabilizer for a target of "70" for your SWG pool.
    To increase CYA via granular stabilizer, place the required amount as calculated by the Poolmath calculator into a white sock and place in the poolside skimmer basket. For those concerned about suction flow to the pump, suspending the sock near a return jet or from a floating device will also suffice. Best never to allow undissolved granules to rest directly against the pool surface. Squeeze the sock periodically to help it dissipate. Once dissolved, consider your CYA adjusted to that programmed (target) level. CYA test readings should show a rise in 24-48 hours, however some pools may experience a longer delay to fully register. Best to confirm final CYA in about 5-7 days before adding any more stabilizer/conditioner.
    You can use regular bleach form HEB or Walmart to maintain the proper FC level until your SWG is adjusted. I would recommend an FC of 3 the first day, then about 5 thereafter. PH will be in the 7.5-7.8 range.
    That should get you going. Feel free to post a full set of results once you get going and we'll give it a look. Nice to have you with us.
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    Hello and welcome
    Chris- Macomb, Michigan 20,000 gallon pool IGP. 16 x 32 Hayward Ecostar pump. Hayward 24 inch sand filter with Zeo sand. Hayward Aqua plus P4 automation board with T-15 turbo cell. Hayward H150 heater millivolts style. Polaris 9300 robot vacuum. New maytronics titain plus vacuum cleaner Test kits TF-100 and color Q7 TEST KIT.http://tftestkits.net.
    Jul 2016
    Joshua, TX
    4
    Thanks for the quick reply, Should I assume the CYA level is 0 & start with the full 79oz per pool math or test first?
    Thanks again
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Yes, there is no CYA in tap water.
    Jul 2016
    Joshua, TX
    4
    I filled the pool Friday added 210 pounds of salt, started the stabilizer I put about 2.5 LBS in a sock in the skimmer & the rest of the first 4 LB container in a bucket stirring occasionally & adding the cloudy water to the pool sock & bucket are almost empty so I will add balance of stabilizer tonight.
    Immediately after filling pool chlorine tested at 5 with pool strips that came with the pool & I could smell chlorine.
    I set the pump to boost tested chlorine at 4 PM yesterday with TF-100 kit chlorine at 0 PH at 7.2 salt 3100, I added 65 OZ bleach bottle states yields 7.86% available chlorine tested this morning chlorine FC 13 CC .5 PH still 7.2 so I assume my saltwater generator is working.
    I have had it running on boost since I started but has set error codes for salt level too high a couple of times so I reset it & turned off to swim I have not tested other chemicals yet figured I would be better off adjusting 1 or 2 at a time.
    What should I do Next?
    Clint
    DFW, TX
    24,514
    It takes 24-48 hours for the salt to fully mix in the water. Post a full set of test results. You're looking for this, Pool School - Water Balance for SWGs
    Jul 2016
    Joshua, TX
    4
    First full test:
    FC 11.5
    CC 0
    PH 7.2
    TA 90
    CH 125
    CYA 40
    salt 3450?
    From what I have read so far my CYA is probably not accurate yet because pool only been up since Friday I started with 4 pounds Clorox pool & spa chlorine stabilizer per pool math should need another pound to get to 70 but I think I will wait to add till I get a good reading.
    PH at 7.2 is also not accurate due to high chlorine levels?
    Using AquaChek strips to test salt there is not a definite line it kind of goes to a point so I am splitting the difference from bottom of color change to point is this correct? I kind find anything definitive on this.
    I am going to start my SWG for 5 hours beginning at 9 A.M. today I work a mid shift so I can verify pump is running before I leave for work.
    Does all this sound right so far?
    pooldv your pool is beautiful BTW
    Thanks again,
    Clint
    Jun 2014
    15,274
    Hello Clint. Congrats on the test kit! Your pH will be "off" when FC is above 10, but usually pH reads high. You're not that far above 10, but next time the FC drops just under 10 I would re-check the pH to make sure it's not too low. Stabilizer if added Friday should be mostly mixed with the water by now if you added it via the sock method and it's all dissolved. But at least you know now how to test and that ideally you want a CYA of 70 so that's good. I'm afraid I don't use the salt strips so I can't help you on that one. Someone else should chime-in shortly. Have a nice day.
