Thread: Very high chlorine and alkalinity
    My brother-in-law followed the recommendations of a local pool store, and his pool is now messed up. I tested his pool with my TF-100 test kit and got the following results. The pool is a small 2,500 gal above ground. The water is currently cloudy.
    FC= 23.0
    CC= 0.5
    pH= 7.2
    CH= 175
    TA= 300
    CYA= 20
    Temp: 78 degrees
    When I plug the numbers into the pool calculator, it shows a CSI of 0.1.
    What is the best way to lower the chlorine level? Hydrogen peroxide or sodium thiosulfate? The pool gets about 7 to 8 hours of direct sunlight each day.
    Should the TA be lowered? Is the only way to do that the acid/aeration process?
    22,400 gal, in-ground vinyl, sand filter; TF-100 Test Kit; Finger Lakes, NY
    Kdfoust's Avatar
    Feb 2016
    Riverside, CA
    10
    Re: Very high chlorine and alkalinity
    The FC will come down on it's own from sun exposure. For example, in Southern California my pool looses 2 or 3 PPM each day just from sun.
    27000 gallon lazy L, with attached spa, DE filter, Heater, variable speed pump. I do it all, no pool fools on my property!
    Jun 2014
    15,189
    jrh, since your brother-in-laws pool is less than 3K in size, you should refer to the Pool School - Guide for Seasonal/Temporary Pools. It's really meant for those kind of pools that can just be dumped and refilled rather quickly. But to answer your basic questions:
    - FC will just drop quickly on its own. I wouldn't add anything
    - CSI should not apply to his above ground pool (no plaster)
    - TA lowered? For a plaster pool perhaps, or a pool much larger. But for this one, I wouldn't worry about it right now. Once you refer to the seasonal guide, you'll see the most important issues are FC, CYA, and pH. But yes - acid/aeration is how we lower TA.
    Hope that helps.
