Thread: Mind of its own! Jets won't turn off, can't set temp, etc.
    Jul 2016
    Lockport/il
    2
    Inherited a poorly taken care of destiny river spa (viking) hot tub when we moved in. It came with a handful of cracked pipes and one broken motor for the jets. We repaired the cracks, but not the motor only because we don't want to keep sinking money into this if it's going to die on us soon.
    Our current issues are that the working jets won't shut off. In all modes when the jets button is pressed it goes on high, again low, and the third time off and then right back on to low. Repeat and it just goes high and low, no off not even for a moment. In sleep mode we can't set the temp lower than 80. Lastly, and not a big deal, but the lights stopped working in and around the tub. Shortly after the lights went out we noticed the jets and temperature. So not sure if they are related.
    I reset the system, so to say, by shutting off the fuse and turning it back on. Issue continues. So I killed the fuse for the time being...not looking forward to the electric bill.
    Any idea as to what is going on?
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,280
    Re: Mind of its own! Jets won't turn off, can't set temp, etc.
    Just a to get noticed...
    Sounds bad, maybe a call to the manufacturer or dealer?
    If on your next post, you "Go Advanced" and change the title to Destiny River Viking Hot Tub, Mind of it's own...
    Someone who has one might jump in
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jul 2016
    Lockport/il
    2
    Thanks for the tip!
