Thread: Above ground Deck Build
    Jul 2008
    Indianapolis, Indiana
    7
    I have an above ground pool and will be building a deck on one side in the next few weeks. I was wondering which way would be better for the height of the deck. should the deck be slightly below the side caps, the same height or slightly higher then the caps? If higher would you run the boards to the inside edge of the cap or somewhere toward the outside?
    I need to be able to put a winter cover on the pool so I know I need space for that, just not sure which would work best.
    Frank.
    P.S. I'll post pictures of the construction process when its complete.
    18' AG Vinyl Pool (7,500 gal)
    1.5 HP Hayward pump and sand filter 150#
    Using the BBB Method
    Taylor K-2006 test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Above ground Deck Build
    Hi and welcome,
    If you do a google search (bottom left corner) of the forum for this subject, there have been a few threads discussing it, and you can see several examples via pics users have posted.
    Good luck with your build!
    PS. my boards are even with the top cap and I have a 1 inch gap.
