Thread: My friends pool is very cloudy, please help!
    Mar 2016
    Chino Hills, CA
    190
    Hello pool family,
    So I have my pool dialed in very well but my friend who has an older pool is having an issue. His water is so cloudy that you cannot see a few feet down. I will post what his results are and maybe you can point us in the right direction. I think he will need to drain maybe 50% and refill to start but I’ll let the pros chime in before I make these recommendations to him.
    He DOES NOT have a SWG. His pool is roughly 14,400 gallons and uses a sand filter.
    FC – 1
    CC - .5
    pH – 7.4
    TA – 80
    CH – 530
    CYA – 90
    We put in 10 cups of 10% liquid chlorine which brought it up to FC 7.5/CC .5.
    He does use those chlorine tablets that float in the pool which I understand puts more CYA in the pool. I think he may need to get rid of these right away.
    I think his pH and TA are within reason but CYA and CH are possibly a bit to high, thoughts? Chlorine is way to low and for this reason I had them raise it up before I left their house. I will go back tomorrow and recheck.
    30,000 Gallon Pool IG (Pool 18' X 38' / Spa 7' X 7') - Pentair IC40 SWG - (1) Pentair Intelliflo 2 VST Pump - Pentair DE FNS-Plus 60 Filter - Pentair Mastertemp 400 Heater - Pentair Easytouch 8 - Pentair Electronic valves - Pentair 5G Color LED Pool/Spa Lights - Pebble Sheen Mini Tahoe Blue - Auto Fill/Over Flow - Taylor K-2006C - Completion 3/2016.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: My friends pool is very cloudy, please help!
    Quote Originally Posted by eostrike View Post
    Hello pool family,
    FC – 1
    CC - .5
    pH – 7.4
    TA – 80
    CH – 530
    CYA – 90
    I agree with draining to reduce CYA. CH might be reduced in the process. Then SLAM is in order.
    Is your friend willing to possibly convert his pool management from using chlorine tabs in a floater? If not, you will find yourself spinning your wheels trying to help.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mar 2016
    Chino Hills, CA
    190
    I am going to try and get him to remove the tabs. In this current state is the pool safe to swim in? Thanks for being the first to reply. Look forward to hearing everyone's opinion. I only have experience on my pool and have it dialed in but this is an issue I need help with.
    Quote Originally Posted by AimeeH View Post
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    883
    If you can't see the bottom of the pool through the cloudiness it is unsafe to swim in.
    That not being an issue- you can swim in an FC up to SLAM level for the relevant CYA level. If it is 90 at the moment that would be 35 FC. But if you drain the pool to lower the CYA obviously that number would change.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Mar 2016
    Chino Hills, CA
    190
    Thank you Jezza. Yeah CYA is 90 and FC was 1 until I raised it.
