Results 1 to 9 of 9
Thread: A Stenner Success Story
    First, thanks to this forum for cluing me on to peristaltic pumps. I travel a lot, so I absolutely love this setup.
    I bought a Stenner 45MPH 10 gallon per day, about $210. Bought an Intermatic programmable timer, about $20. Programmable. Bought a 15 gallon opaque blue tank for $20. Hardest part of the installation was lugging the chlorine home.
    I run my pump on low speed for circulation most of the say, but ramp it up to high speed for cleaning. I have the Stenner programmed to run for 50 minutes a day during the pool pump's high speed run. It's easy to change the program for a longer or shorter run, or to simply override the program and turn the pump ON.
    I'm going to replumb my pool next year, so here's the cobbled together installation for this season.
    20' x 40' plaster pool with 6'D 4-jet spa. Estimate 23K Gallons
    Raypak ASME 400k propane heater, Pentair Intelliflo pump, Pentair Quad DE 100 filter
    Liquid Cl via Stenner 45MPHP10 pump and Intermatic HB880R timer
    Loop-loc cover, Letro Legend II sidewall cleaner, soon to be replaced
    Live in CT, use pool from mid-APR to mid-NOV
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: A Stenner Success Story
    Nice work!
    May 2014
    Jacksonville, FL
    22
    Where did you purchase the Stenner pump?
    19k gal, IG, Rectangle, Pebble, Pentair Clean & Clear Cartridge, Intelliflo VS Pump, IntellichlorSWG, Aquacal SQ-155 Heatpump, Aquaclean Aclean1 Robotic Cleaner, TF-100, Dec 2013, Jacksonville FL
    Stenner pump was purchased from Locke Well and Pump. $208. Pump ships with feed hose and all the kibbles and bits to get it connected. I left my hoses long and looped them on the wall because I'll be relocating things next spring.
    Without a doubt I think the better way to go with these pumps is to get a fixed rate pump and a timer to control it versus the variable feed pump that is running for hours at a time but meters chlorine through the "click click click" mechanism.
    http://http://www.lockewell.com/inde...roducts_id=145
    Nectarologist's Avatar
    Apr 2015
    New York
    426
    That is awesome. Do you get the 5 gallon container filled from the pool store or do you fill from chlorine or bleach jugs? I don't think I can get the 5 gallon chlorine already filled where I am.
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    The blue storage jug is a 15 gallon jug, used. It was used to hold juice concentrate. Smelled pretty darn nice when I got it!
    I buy 12% chlorine by the 4-gallon case at a local discount store, NOT a pool store. Filled the 15 gallon blue jug with that.
    Jul 2014
    Sacramento, CA
    241
    Quote Originally Posted by Mongo View Post
    Did you buy the storage tank online, or from somewhere local? I've found them (new) at Uline for closer to $60 with shipping; would love to find one locally either new or used.
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Quote Originally Posted by jmastron View Post
    As you discovered, new were expensive, so I first looked used/local on craigslist. There were some available, but the sellers were asking $35-$40 firm.
    Looked on eBay, which I normally don't do. Found someone selling and they had a "make an offer" button, so I offered $20 with shipping included and they accepted. I don't have a record fo the transaction, but I recall the seller being in Virginia.
    Jug arrived fine, great shape, just a residual sweet smell from the juice concentrate. Looks pretty new.
    Jun 2016
    vienna ohio
    93
    Thank you for helping me with my Christmas list! Much appreciated! Looks great
    40x20 in ground, 33,000 gal, vinyl liner, Hayward 300lb pro series sand filter, Hayward 1.5hp super pump, aquabot xtreme, chlorine
