Thread: Filter shooting dirty water back into pool after about 15 seconds of running cleaner
    Jul 2016
    Lincoln, Nebraska
    6
    Hi! First post for me here on TFP. So I had an algae bloom and am coming back from it. Killed it all and it all settled out to the bottom. Now working on vacuuming it up with the dirt devil pool cleaner. However, after I have it running for about 15 seconds, the return jets start blasting dirty water back into the pool. Seems the algae getting vacuumed up is just going right thru the filter instead of getting caught. I then backwash, rinse, and start again and the same thing happens? Read a few other posts, so I'm going to take a peek inside the sand filter. Any help is welcomed! Thanks!
    Oh oh I have a 24' diameter 12,500 gallon pool.
    Jul 2016
    Lincoln, Nebraska
    6
    Re: Filter shooting dirty water back into pool after about 15 seconds of running clea
    Took apart the sand filter and pulled out the laterals. No visible cracks, sand looked fine aside from some small chunks that had hair in them. Spose those could have clogged the filter a bit, but I wouldn't think too much. Any ideas guys? Should I put the sand back in and try it, or should I get that zeo-sand stuff?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Welcome to TFP!
    Most people don't seem to like zeolite, but some folks love it. I would use sand and there is no need to replace it. There is a link to deep clean in this page, Pool School - Maintenance and Cleaning of Pool Filters, maybe something there will help.
