Results 1 to 7 of 7
Thread: High CYA and just bought bucket of pucks
    Jul 2016
    Peoria/AZ
    37
    Split by moderator from HERE. jblizzle
    So I bought a big box of stabilizer pucks from Costco thinking I need them. Do you use them or not daily? My cya is high, 100 but I will not do a partial drain till winter here in the Phoenix sun. If you don't use them, then do you add chlorine daily. I am keeping my FC at 5 right now.
    20,600 gal. In-ground Waterfall/Slide, Hayward Century 1.5hp single speed pump, Hayward S311SXV 5.0 cu. ft. sand filter, Hayward Navigator vacume & 5 t-port in-ground pop up pool cleaner system
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: Pucks without stabilizer?
    You should keep your questions on the same post as it will help the other users to answer your questions better You stated on your other post that you were going to order one of the recommended test kits. Did you receive it yet?
    The CYA testing maximum is 100, so your CYA is probably higher. With the recommended test kit, try diluting pool water with 1/2 tap water. Then double the result.
    You could do a reverse osmosis treatment which will remove the CYA, CH and just about everything else from your water. This will negate you having to drain and refilling.
    What does your water look like now?
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jul 2016
    Peoria/AZ
    37
    Sorry. I was reading another thread & thought it posted to that. I am trying to get used to this tap talk app. Anyways, I did get the kit. Tested it last week.
    Fc 3.5
    Cc 1
    Ch 500
    Tac 130
    Cya 100
    I have been keeping my Fc at 5 pool looks beautiful. I use 2 stabilizer pucks in the floater too. I will do my weekly test tomorrow. My ph daily test is 7.5 consistently. Should I keep using the pucks?
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Quote Originally Posted by zzjams View Post
    Fc 3.5
    Cc 1
    Ch 500
    Tac 130
    Cya 100
    Sent from my SM-N920V using Tapatalk
    You should remove those pucks ASAP as they are only adding to your very high CYA. Again, your CYA probably higher than 100, so you need to dilute it to see where it really is. Pool School - CYA
    You should increase your FC to 12 for now using bleach. Here is the Chorine CYA chart: Pool School - Chlorine / CYA Chart
    Some pool stores carry 10% chlorine and Wal-Mart has 10% chlorine in the seasonal section or you can get the 8.25% in the laundry section. Don't get splass-less, outdoor, fragrances, etc. just plain bleach.
    Karen
    Jul 2016
    Peoria/AZ
    37
    Do you ever use those pucks even when your cya is low or it is something you do without? Because I can return them because they are unopened. I have been using the 10% walmart chlorine. If my ch is 500 should I have my ph lower? Regular tap water is 200 ch here. We tested it with our kit.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Vacations, stain remover, slow CYA increaser. If it's a big bucket take them back. I haven't gone through a small tub of them in 3 years.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2016
    MD
    195
    Re: High CYA and just bought bucket of pucks
    If you didn't open it, return it. Costco is good. I returned a tub i bought last year this year
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
