Thread: Neverending Filter Problem
    hello Guys I got this problem every summer season after I remove the filter tank to clean my DE Ribs. I put my DE Ribs back in place then the nightmare begins.
    I attach the top of the filter tank and make sure the o-ring is snug in place before installing the bands as they come with 2 bolts spring type loaded to seal the tank... however everytime I do this and start the pool the filter starts leaking until gauge pressure goes up then it stops.
    I have added some pictures where you can see the water dripping here so any expert can help me out here since I know this must be an easy fix and im about to lose the little hair I have left.
    Here is the other side :
    Re: Neverending Filter Problem
    It looks to me like you either need to better lubricate the O-ring, or you need a new O-ring.
    Jun 2007
    New Jersey
    Are you using a rubber mallet to cinch up the band? It makes a big difference. The picture shows tension springs are fully compressed, as they should be. However, the use of the mallet may seat things better and allow the front half to close more completely. I would follow Jason's advice and inspect/replace/lube O-ring, and tighten up again using the mallet. I assume that you have cleaned the mating surfaces, as well as the O-ring, of any debris or crud.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Mar 2007
    Coastalish 'down easter'
    If you plan on replacing the o-ring DEX 2400 - K, you'd better buy one (or more) quickly - it's been discontinued and the only option is to replace the entire filter (you have a Micro - Clear filter and the new clamp assembly they are making won't work with your filter!)
    When you lube the o- ring does it feel squared off anywhere? If it does, it's time for a new o - ring - or a new filter
    Luv& Luk
