Results 1 to 13 of 13
Thread: IC 40 reads low salt; Pentair told me to bring down phosphates?
    Feb 2014
    Jersey side of Philadelphia
    93
    My water is perfectly balanced.
    Salt: 3400
    FC: 4
    Alk: 80
    CYA: 60
    PH: 7.6
    Borate: 30
    Phosphates are high (300) but I usually do not care since everything else is balanced. The same thing happened last year and Pentair sent a new IC 40 (less than a year old). This year my IC 40 just started reading low salt which is inaccurate.
    Called Pentair and they said to add phosphate remover as it can impact the cell's ability to read the salt level properly. Does this make sense?
    24,500 Gallon (640 SF) Inground Gunite Salt Water Pool w/ Diamond Brite Midnight Blue Plaster. Pentair IC 40 Chlorine Generating System. Hayward 60 DE Filter. Jandy Aqualink Remote System. Polaris 360 Automatic Pool Cleaner. 50 SF Spa with waterfall feature
    Hayward 440,000 BTU Heater. Two Colorlogic LED pool lights.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: IC 40 reads low salt; Pentair told me to bring down phosphates?
    How are you testing? Just want to be sure those are accurate measurements.
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jun 2011
    Long Beach, CA
    2,790
    Quote Originally Posted by Species 8472 View Post
    Salt: 3400
    FC: 4
    Alk: 80
    CYA: 60
    PH: 7.6
    Borate: 30
    What is the SWG's salinity reading?
    Phosphates do not make SWG's read low salt and it's their way to pass on troubleshooting the system without needing to be there to actually find out what is wrong with the system.
    Feb 2014
    93
    Salt is reading 3400 PPM.....Exactly what Pentair claims is optimal. I am going to call back and get a different rep. Last year, had the same issue and they just replaced it. I have not had much luck with SWG. Third year of this new pool.
    Jun 2011
    Long Beach, CA
    2,790
    Have you tried cleaning the cell?
    Feb 2014
    93
    Quote Originally Posted by ping View Post
    When I first opened the pool mid-April, I cleaned the cell with 100% vinegar as recommended by the pool opening company. I have not cleaned it since then. I am not entirely certain how to clean with muriatic acid without making a mess of things?
    Quote Originally Posted by GreatCanadian View Post
    GC
    I have a Taylor commercial grade test kit. I also tested at Leslie's pools as requested by the Pentair technician who apparently felt that Leslie's would be more accurate. My results comported with those of Leslie's.
    Jun 2011
    Long Beach, CA
    2,790
    You need to remove the cell and inspect it for scale.
    If the cell has scale then you should plug one end of the cell and use a 4:1 mix of water to acid to clean the cell.
    Feb 2014
    93
    Salt: 3400
    FC: 4
    Alk: 80
    CYA: 60
    PH: 7.6
    Borate: 30
    So, I added a phosphate remover and the SWG started claiming appropriate salt levels? Go figure.
    Any chemists who can explain what is going on? Coincidence? A chemical reaction?
    Jun 2011
    Long Beach, CA
    2,790
    I'm going with coincidence.
    The cell might be going out when it reverses polarity. One side of the cell might work fine but when the cell reverses its polarity it will show low salt. Try to find out the cycle time for the IC-40 and keep a watch on it for when it switches the polarity.
    It would still be a good idea to see if there is any scale inside the cell.
    Feb 2014
    93
    Okay...Just removed SWG and will use muriatic acid solution and see what happens.
    Feb 2014
    93
    I forgot ask--How long should one let the muriatic acid solution sit on the scales? I let it sit for about 2 minutes, re-installed the SWG, and it now says it reads a fine salt level. I will update tomorrow because it could be oscillating between low and good salt levels as it seemed to do after I added phosphate remover.
    Jun 2011
    Long Beach, CA
    2,790
    The time depends on how much scale there is inside the cell. If there isn't any scaling then it should not be cleaned. Any heavy buildup should be first removed with a wooden object to prevent scratching off the coatings on the cell plates.
    Feb 2014
    93
    There was no evidence of visible scaling (or not bubbling) so I let sit for about two minutes.
    So far this AM the SWG is indicating a good level of salt. Let's see if it continues to read such or if it oscillates again in a few days.
    Could have less to do with scaling (new SWG last year) than with a malfunction in the SWG itself
