Results 1 to 12 of 12
Thread: High PH
    Jul 2015
    Eaton Rapids
    41
    High PH
    Hello, I have a question about high PH levels in my pool. I have a 18 ft circular Pool (7600 gallons) and a Intex 3,000 GPH Sand filter. About 3 weeks ago I got back from a work trip and my pool was green. I did the SLAM process and now it's nice and blue again. There is still algae hanging around on the floor of the pool but I've been able to brush and vacuum for the most part.
    My issue now is that my PH/TA is really high. When I tested last night (using Taylor k-2006) my PH was above 9 and my TA was at 440. I looked at the PoolMath calculator and when I put in 9 with a goal of 7.5 for PH and then put in 440 with a goal of 100 for TA it asks me to put in 103 oz of Muriatic acid. However, if I bump my current PH up to 10 it asks me to put in 332 of muriatic acid which is significantly more.
    I'm wondering what would be a good amount of muriatic acid to put in?
    My current FC level is 2 (I know I have to get this up a little) and my CYA level is probably around 20 (I'm in the process of raising this to 40).
    Thanks for the help!
    7600 gallons AG. Hayward Sand filter. Taylor k-2006.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,195
    Re: High PH
    Right now get the pH down to 7.2 with acid (ignore TA for now) and re-start your SLAM. Visible algae means you stopped too soon. The clear water part of the SLAM means you see no algae.
    Lowering TA is a multi step process, not a one time addition of acid.
    Support the site
    Jul 2015
    Eaton Rapids
    41
    Re: High PH
    I guess my question though is how much muratic acid should I be dumping in? A couple weeks ago I noticed my pH was high and dumped a gallon of muratic acid in my pool and it didn't seem to do a thing. I just can't seem to get my pH level down to acceptable levels.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: High PH
    If you dumped a gallon of MA in a 7600 gallon pool and it didn't do anything, that wasn't MA.
    Always use PoolMath to determine correct amounts.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Aug 2014
    Houston tx
    2,525
    Re: High PH
    What percentage of MA are you using? What is the date on the bottle? Maybe it was old. Not an expert, just throwing out ideas....
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jul 2015
    Eaton Rapids
    41
    Re: High PH
    Quote Originally Posted by Mr Bruce View Post
    I'm sorry I misspoke. It did lower my pH but a week later it's right back up to high levels. I guess another question is what is making my pH so high? I don't know anything about pool chemistry so I apologize if it's a dumb question.
    May 2014
    Franklin, NC
    9,195
    Re: High PH
    Aeration causes pH rise. This could be a waterfall, returns spashing the surface, kids splashing around - anything like that. Plus, high TA causes it to rise faster.
    But, we need to eradicate the algae before we worry about the TA.
    Support the site
    Jul 2015
    Eaton Rapids
    41
    Re: High PH
    Quote Originally Posted by tim5055 View Post
    It's interesting you say that. I have a Summer Escapes pool and the return is a little above the water line so my filter has been running pretty much non-stop while I've been slamming (about a week and a half) and it's splashing a lot of water on the surface.
    May 2014
    Franklin, NC
    9,195
    Re: High PH
    Quote Originally Posted by Newerabs View Post
    That, plus your high TA could do it.
    So, let's SLAM and get rid of the algae.
    Support the site
    Jul 2015
    Central Valley CA
    1,109
    Re: High PH
    As others have said sounds like the SLAM is not complete, on the pH question I think the reason it is telling you to add so much MA when you put ever higher numbers in the calculator, is that pH is logarithmic so a seemingly minor increase in the number is a major increase in the amount of MA needed to deal with it. I think a safe amount would be 1/4 gallon of 31% at a time with he pump running and check the progress every 30 min or so. because it's logarithmic I would think you can be more aggressive (add a bit more) to start and back off as you get near your target.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jul 2015
    Eaton Rapids
    41
    Re: High PH
    I guess I'm not sure how I'll know once all the algae is gone. Right now my water is crystal clear but there is sandy brown stuff on the floor every morning. Is that "dead" algae? It seems to brush up pretty easily and I can vacuum it up (most of the time). But it just comes back the next day. Sometimes there is a lot of it sometimes not. I have no idea how algae works (obviously)
    Aug 2015
    Orlando
    116
    Re: High PH
    Been there, done that, got the T shirt. Follow the SLAM process, mainly the OCLT test. Sun eats up Chlorine, so test FC after sun down, and write down your level. Then check first thing in morning. If more than 1 ppm FC was used it, it was the organics in the pool, and your SLAM isn't over yet.
    When your FC doesn't change overnight, all the organics are gone. Also be sure to clean your filter, as the organics might be hiding in there too. My cartridge was full of little ants/bugs, and my SLAM wouldn't finish until I got rid of those critters.
    Just my advice
    Phil
    ~9600 gal gunite pool, NEW July 2015; Pentair Intelliflo 2 VST pump; Pentair C&C 150 filter; Pentair Intelliclor IC40 swg; solar heat w/ Pentair Solartouch controller, screened. Taylor K 2005 test kit, FAS-DPD separate test, Taylor K1766 salt test
