Results 1 to 9 of 9
Thread: Not Enough Chlorine Produced
    Our pool at our families vacation house isn't producing enough chlorine.
    I tested it and it's coming up 0.5 FC. The SWG is running at 100% for the last 1.5 days. The pool is 100% balanced otherwise. Salt level is 3000 ppm.
    Any thoughts?
    18,000 gal fiberglass pool
    Pentair IC40 SWG
    Pentair MasterTemp
    TF-100 Test Kit
    18x36 29K gal Gunite - 1 HP Hayward Super Pump
    Hayward Aqua Rite - 40k Cell - 24" Hayward Pro Sand Filter
    Polaris 380 w/ booster - RayPak 336K BTU Propane Heater
    Twitter: @jfgreco
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    880
    Re: Not Enough Chlorine Produced
    Yes- can you give us the full results
    FC
    CC
    pH
    TA
    CH
    CYA
    How long are you running your your SWG for at 100%?
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,178
    First, add liquid chlorine to gets it to where it should be.
    Any lights on at the salt cell? Is the salt level OK?
    My next step would be to conduct an OCLT to see if something in the water is consuming all chlorine produced.
    Support the site
    Here you go.
    FC-0.5
    CC-0
    pH-7.2
    TA-90
    CH-310
    CYA-80
    Salt-3000
    How long are you running your your SWG for at 100%? We are running it for 11 hours a day.
    I took a sample right out of the inlet and that was 2 ppm.
    It is consistently 0.5.
    Salt cell has all the proper lights on.
    Twitter: @jfgreco
    Jezza's Avatar
    Jan 2015
    880
    OK- you are definitely running too low for your CYA of 80.
    I would follow up with the OCLT tonight to confirm the presence of organics and prepare for a possible SLAM. You could consider using liquid chlorine to bring your FC up to 10 FC to get a solid number for the OCLT.
    K-2006
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    If your SWG is working properly then you likely have organics. I believe you might be on the very edge of a full blown algae bloom, and the SWG is producing just barely enough to keep it at bay - for now. As suggested above use bleach and get your FC level up to where it should be. Perform an OCLT.
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    May 2014
    Franklin, NC
    9,178
    Yes, if you tested 2ppm at the return then the FC is being being consumed by organics. Verify with an OCLT, but it's time to SLAM.
    Support the site
    We began slamming yesterday. We lost some overnight so continuing to slam today. Pool looks a million times better.
    Any tips on helping chlorine drop once we pass the OCLT?
    Twitter: @jfgreco
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    FC will drop on its own pretty quickly. It is safe to swim up to shock level for your CYA, FC/CYA Chart
