Results 1 to 15 of 15
Thread: What do you do with all the bleach bottles?
    May 2009
    Blue Springs, MO
    18
    Trash, recycle? Has anyone figured out something useful or creative to do with them?
    IG pool, 20k gallon, vinyl liner, sand filter
    Feb 2008
    Denton, TX
    5,061
    Re: What do you do with all the bleach bottles?
    I just put them in the recycle bin usually. Now I have retained a couple to put water in for freezing large blocks of ice for ice chests, but since we have curbside recycling, I'll generally just put them in the bin.
    I know...I wish I had a novel discovery to make them more useful. I've been trying to get my local pool store guy to start stocking bulk sodium hypochlorite so I could go the refillable carboy route. No luck thus far though.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yard Sculpture? Just kidding
    Guest
    I cannot offer an answer, but I would like to nominate this as the best question ever posted on this board.
    I've been putting mine in the recycle bin. it gets a little embarrasing after an aglae problem or major shock treatment.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    Quote Originally Posted by bhunt99
    I found an innovative way to keep my winter cover on...I saw that pool stores sell these vinyl pillows that you fill with water and attach to the top rail and lay on top of the winter cover. This keeps the wind from getting up under the cover and blowing it around or off. I have a security fence around the outside of my pool so on every other upright, I tie a bleach bottle half full of water to a small two to three foot piece of rope and lay it on the cover. This coupled with three to four clips on each section of pool wall made for a very strong winter cover. We had winds at one point this winter that blew up to 70 miles an hour and knocked down sever tree limbs on my house...but the cover stayed on the pool. This in my opinion works better than hanging water bottles down along the side of the pool because you are actually providing weight on top of the cover not on the sides which causes the cover eyelets to rip. And the cool thing is that when the water in the pool is not frozen, the bottles still float on the surface of the cover.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Jun 2007
    NC
    255
    I'm not inventive or anything.
    I rince with pool water, smash flat (That's FUN!), and place in the recycle tote. If not smashed flat there is no way that the bottles used to start up the pool would fit.
    I do have 1 or 2 that I rinsed out thoroughly and cut the bottoms off of to use as grain/food scoops for the many, many animals that we have in and around the house. When you scoop bird seed you can then take the caps off and it makes a self-contained scoop and funnel 8)
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    Aug 2007
    Eastern Canada
    54
    http://www.thriftyfun.com/tf22187099.tip.html
    http://www.lauraerickson.com/bird/Sp...FIGallery.html
    18X36' 25000 gal Jacuzzi vinyl Inground Pool (1985) with resin sidewalls, newer Jacuzzi 1 hp two-speed pump and sand filter. Raypak propane heater, Rainbow 320 chlorinator (mostly use bleach).
    Softtub 220 portable hot tub.
    Jun 2007
    New Jersey
    653
    Well, it only takes care of one, but: I cut off the top and bottom and split one opposite the handle to make a guard for using my weed-wacker around young trees that the town put along my road. You can kill a young tree with a weed wacker if you cut a circle through the layer under the bark. It works great.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    I use mine for used motor oil and antifreeze and then dispose of at work.
    Oil gets used for the waste oil furnace.
    Recycling company takes the antifreeze.
    I usually keep the bottles and reuse again.
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Aug 2009
    North Central Texas
    1,358
    Great ideas. I like the ring around the plant idea. I've lost lots of new trees and shrubs to rabbits eating the bark all the way around. There are now lots of spray paints in stores, just for plastics, to improve aesthetics.
    Find someone(s) who has a hobby greenhouse. You can fill them with water, put them on plastic shelves, on sunny wall, to collect heat from sun during day. They then release the heat during night to reduce supplemental heating. Works great especially if you have lots of sunny days in winter. I've also used cheap, black garbage bins for same purpose. Then recycle (bottles only) in spring.
    One year before I started smushing them in trash compactor, I took zillions down to road for weekly recycle truck, in clear plastic bags, as is required by our pick-up. I'm talking about twenty 40 gallon bags of recycle (other stuff included as I don't take it down every week). It was so impressive I took pictures. Looks like the truck couldn't take the very last bag as they left one. Next day the bag disappeared so I'm hoping someone was able to recycle them.
    I make a scoop to get the water out of seats when I empty the spa and to get the last little bit that the submersible pump can't get. Very effective and flexible enough that it doesn't catch on the jets or mar the finish. Great for bird seed, dog food, and all other kinds of things. I do, though, like to use a metal one for getting potting soil out of bags.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Aug 2007
    near the swamp
    806
    dumpster
    Feb 2008
    Northwest Indiana
    902
    http://i658.photobucket.com/albums/uu30 ... tos190.jpg
    My winter cover holder downer and keep it from blowing around uncontrolably contraptions...
    Beave
    11,969
    Beave and I invented a new drinking game utilizing the empty jugs one afternoon after DH and I slaughtered him in Corn Hole.
    Jan 2009
    Cupertino, CA
    1,966
    Wow, such creativity.... I get my 12.5% by the case, they wanted a deposit so I return the jugs.
    --paulr
    BBB "Intermediate Swimmer"
    Feb 2008
    Northwest Indiana
    902
    Quote Originally Posted by frustratedpoolmom
    Unfortunately poolmom slaughtered me at that as well!!! I see you say nothing about the one bag to win, throw the other three down on the ground, swish from last camping trip though!
    But chlorine jug drinking games are loads of fun!!!
    Beave
