Results 1 to 11 of 11
Thread: Pentair Globrite
    Jul 2016
    Shamong, NJ
    1
    Pentair Globrite
    I've had to replace 4 of my lights. Moisture behind the lens. Has anyone else had this problem?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    Re: Pentair Globrite
    I had one fail. The others have been fine since day one.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    96
    How hard was it to replace them? I have one that has water in it. It looks like you can just unscrew them and pop the new one in (after turning off the power). Is this right?
    18k vinyl IGP, Sand Filter, EasyTouch Control Sys, Pentair Intelliflo, Intellichlor IC 40 SWG, Rheem Heat Pump.
    Apr 2013
    Sacramento, CA
    2,769
    Manual:
    http://www.pentairpool.com/pdfs/620053.C.GloBrite.pdf
    Its not quite that simple.
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    96
    Quote Originally Posted by gwegan View Post
    Hmmm. This might be a job that I pay to have done...
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    I wouldn't say its difficult if you've pulled wire before and have electrical knowledge. There really isn't anything to them.
    -Brian-
    POOL BUILD
    Jontmiller's Avatar
    Mar 2013
    Newtown, CT
    20
    I have had two fail...( same location) one under warranty. For me it was 2 out of 10 but I have fished some wire in the past....fish tape and patience I would think you could do it just fine...there expensive little f**rs though.
    Separate note....the one I replaced doesn't sync color wise with two others....any thoughts ? Reset controller any way?
    AlanE's Avatar
    Jun 2013
    Cape Haze Peninsula, Florida
    178
    Posted in another thread, we lost two in lightning. I didn't replace them yet as they are too expensive. I have seen poor reviews of these lately. One issue was the water behind the lens. I don't know of any other light that we could use to replace it. Does anyone? Short of replacing the niche I think we're stuck with GloBrites.
    23.6x14 IG free form ~8K gallon, Pentair VS 3050 Intelliflo, GloBrite LED lighting w/IntelliBrite controller, Aztec Cobalt water tile. CLI Carolina Blue pebble finish, Bronze pool cage, 336 sqft Heliocol solar heating. Build Thread and landscaping Solar heating install
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    96
    I ended up getting someone to do it. It was expensive, and I think I could have bought the unit online and done it myself. But water, electricity and my lack of knowledge doesn't seem like a good combination.
    The light was also causing my panel to short out, so I had to run the pool pump manually. The repair guy showed me that I could have just disconnected the light and solved the problem. But I'm comfortable with most pool stuff, but not so much with the electricals!
    AlanE's Avatar
    Jun 2013
    178
    Don't blame you. Better safe then dead.
    Jun 2018
    Spring, TX
    2
    Hi, I dont want to create new thread. I need to replace two Pentair Globrite in the in ground pool. I did replace two lights once when they were under warranty. This time they are out of warranty. I have been searching all day and look like these lights need to change more often...and they are expensive to change. I want to see that I can do it myself.
    1. Do I have to drain the water to below the lights?
    2. Can replace Pentair Globrite with Pentair Intellibrite? Are they using the same niche? I may want to use Intellibrite at the deep end.
    Thanks.
