Thread: Surge Protector
    Jun 2015
    Baldwin, Maryland
    146
    Surge Protector
    Quick ?, I see these at home depot;
    Square D QO Surgebreaker Surge Protective Device Takes 2 Load Center Spaces-QO2175SB - The Home Depot
    I would like to get 2, install one at my main panel, and a second at the sub panel for the pool. Will that work?, or will they not work like that?
    Thanks!!
    13.6K AG (I think?) 32'x16' Oval, Pentair SM8150 cartridge, Pentair SR400LP, Hayward Power Flo Matrix 1.5HP pump, Installed spring 2014 (hand me down, 4 years old when acquired), TF-100 Pool water test kit w/speed stir, Intex SWG (going since 2014), Well Water used for fill/top off
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,766
    Re: Surge Protector
    The HEPD80 from home depot is a lil more money but its a much better surge protector for you panels.
    http://www.homedepot.com/p/Square-D-...PD80/203540660
    I have one of these in my main panel and my pool panel. They work just fine that way.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jun 2015
    Baldwin, Maryland
    146
    Re: Surge Protector
    Quote Originally Posted by CJadamec View Post
    Ok, that sounds like a plan, thanks!
