Results 1 to 14 of 14
Thread: Effect on TA when adding MA at different pH levels?
    Jun 2008
    NW MO
    185
    How much aeration does it take to bring up pH?
    I know this is a very difficult question to answer. I am trying to lower TA so that I can add borates. 3 days ago I brought my pH to 7.0 with MA. I have been aerating by having my return pointed up and I have a sump pump on the other side with a spray hear on the end of the hose - making bubble. In the 3 days I have been aerating pH has risen barely to 7.2. At this rate it will be all summer before I get the TA down.
    When I tested my borates, it is already showing that I have 15ppm in the water. Is this preventing my pH from rising with the aeration?
    24ft AGP 52in deep ~13,500 gal
    Hayward Sand Filter 250 lbs
    SWG
    1.5 HP pump
    425 gal stand alone QCA Hot Tub 15-20 yrs old
    Re: Lowering TA with MA & Aeration
    There is no easy way to estimate how long it should take. You want lots of small bubbles. There is no standard way to compare how much aeration you are getting. It often takes days to raise the PH with aeration, and borates can slow that down significantly.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    mine took what seemed like forever too. I eventually broke down and built (well just stuck together without glue) a couple pvc aerators.
    my-aerator-t7799.html?hilit=aerator
    Jun 2008
    NW MO
    185
    OK, now I have aeration - I hope it goes faster!
    I hooked up the sump pump that we already had in the pool to the power washer.
    SWG
    1.5 HP pump
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    nice. do you get more bubbles if you put that wand a little closer? it almost looks like it's dissipating more than pushing air (via the water stream) into the water.
    Jun 2008
    NW MO
    185
    Pictures were hard to get. The sun was just coming up. I keep playing with the wand slightly. When I had it closer to the water, it was throwing water out of the pool. It is really making the water move and I think it making a lot of bubbles to aid in the pH rise.
    SWG
    1.5 HP pump
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    cool. nice solution.
    Jun 2008
    NW MO
    185
    I got the nozzle closer to the water at a lesser angle - making a bunch of bubbles. pH still isn't rising like I would like for it to, but it is definitely faster than before.
    SWG
    1.5 HP pump
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    heh, well, with my two pvc aerators it still took many hours.
    Jun 2008
    NW MO
    185
    I saw a chart (linked from here) yesterday that showed the relationship of the level of pH and the level of TA and the percentage that TA was affected when adding MA. Now I can't find it. Does anyone have a link to it?
    SWG
    1.5 HP pump
    Re: Effect on TA when adding MA at different pH levels?
    A fixed amount of muriatic acid (for example one cup) will always change the TA by the same amount, regardless of what the current PH is. So there wouldn't be a chart showing exactly what you said. You can see how much some amount of acid will lower the TA using the effects of adding chemicals section at the bottom of my Pool Calculator.
    Perhaps you are talking about this chart? It doesn't show what you just said it shows, but I could imagine someone describing it that way.
    Jun 2008
    NW MO
    185
    Yes, that is the chart I was referring to. I had forgotten exactly what it showed, but thought it would be helpful. Thanks for deciphering for me!
    SWG
    1.5 HP pump
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    571
    Quote Originally Posted by reebok
    Very cool!!
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    that was kind of misleading on my part. that thread is what dman2b showed me as an example of how he did his. I just reposted the link, it's not actually mine.
