Results 1 to 14 of 14
Thread: Hasa Pool Liquidator C201
    Jun 2015
    Oak Forest IL
    20
    Whats everybody take on this? Is it worth 250? I'm gonna switch over from a Hayward 210 tablet feeder. My cya is getting way to high and now I have to dump half my pool. Is there something better out there for the price? Thanks again!
    24 AG 14000g
    1.5 Blue torrent pump w/ Black Diamond cartridge filter Hard piped
    Hayward Auto feeder cl200
    Dec 2015
    Newington, Connecticut
    113
    Re: Hasa Pool Liquidator C201
    I like mine, like anything you have to get use to it. So far no major issues
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    22,550
    What does your filter pressure run normally?
    How close is the equipment to the pool?
    Do you get a lot of debris in the skimmer at times?
    The LQ (Liquidator) is a good tool, but struggles if you have low suction head or get lots of debris in the skimmer at times.
    For the amount of money you quoted you could get an injection pump and timer. It delivers a set amount of FC to the pool regardless of system pressures.
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    I have had mine in use since May, I read the suggested improvements from the forums here and I have been extremely happy with it.
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    Jul 2016
    East Greenbush
    2
    I'm on my second season with the liqudator 3/8" tubing upgrade kit. It has been working very well for me. Here's a tip on getting enough flow through it. Originally with mine, even with the output side of the tank plumbed to the pipe on the suction side of the pump, I was not getting any flow. As long as the liquidator is plumbed between the shut off valves and your pump, on the intake side, slightly shutting off the valve / valves will create more suction on the line and increase the flow from the liquidator. This is how I have to set mine to get it to flow. I actually get 0 flow if I don't slightly shut my intake valves before the pump. I learned this when I had my Kreepy Krawly vacuum hooked up and got way too much flow. Another tip, make sure to adjust your feeder valve on your liquidator tubing while vacuuming or you'll super chlorinate your pool in no time, as the flow meter that comes with liquidator is topped out when I vacuum. Over time, you'll figure out the ideal flow setting for your pool. This will change on cloudy days when the sun is not burning up the Chlorine, as you will need less on cloudy days. Over all, I can leave the house for a few days and the pool is perfect when I return. Screw tablets and stabilized chlorine's where you can't control proper water chemistry... Add stabilizer separately when necessary.
    Apr 2013
    Sacramento, CA
    2,769
    If you have a single speed pump, and get good suction, then the Liquidator works fine. It has limitations with variable speed pumps, poor suction and for some mystery white stuff. You can for just a bit more go with a Stenner pump which does not have these issues, it delivers a set amount of chlorine to the pool regardless of the pump or suction.
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Okay, I have a slightly different take on this. I have the 3/8 LQ. I am happy with it. BUT we have been having many people over for pool parties every two weeks. And this is TX. It has been 98 degrees for two or three weeks straight now.
    Even if you have a LQ, be prepared to dump in one or two gallons of bleach after a party. I don't know where the FC goes, but it does. When it is this hot, be prepared also to augment with a gallon or two. The LQ is great (IMO), but there is no free ride.
    Right now, I am just wearing the old clothes and dumping in pool and trying to keep up.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    Apr 2013
    Sacramento, CA
    2,769
    MarkTX your point is valid but it applies to any automated delivery system. They will all lag behind, Stenner, Liqudator, SWG all will need help after heavy pool use.
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Quote Originally Posted by gwegan View Post
    Well yes, good point. What about a closed loop system? Why can't someone make a good, <edit>relatively inexpensive,</edit> trouble-free one? I know they must not exist, or we would all have one. Hmm.
    I love mine. Bought the upgraded one from Amazon last spring and it did seem pricey, I'll probably cobble the next one together DIY-style. I built a little fence and cover around mine to shade the chlorine from the Florida sun.
    We used to be bad about maintaining the chlorine level consistently. This has solved that and no algae since. It also drove home just how much bleach we SHOULD have been adding all these years.
    It installed easily and I believe it's worth a try.
    13,000 gallon in-ground, Pentair Superflo VS, C-1750 cartridge filter, Liquidator, sparkling clean water!
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Alright, this is addressed to the more recent Liquidator (LQ) owners.
    When I got my LQ, I noticed how, when filling the funnel with bleach, the level of liquid in the funnel would drop below the level in the tank. That is because liquid chlorine is more dense than water, of course.
    What I did not notice, over time, is that it was taking longer and longer to add the bleach without overflowing the funnel. A few days ago, standing in the hot Texas sun, I realized it was taking about 20 minutes to add two gallons. Waaaay too long. Something was not right. And not fun.
    Lacking any better sort of tool, I raided our closet and straightened out a rubber-coated wire clothes hanger. Stuck it in the funnel. Could not push it through. The bottom of the funnel was all caked up. Eventually, something that looked like salt started falling onto the bottom and I made a hole.
    The next two gallons took about two minutes.
    Sorry, no scientific info here, but cleaning the funnel periodically may be a good thing.
    Apr 2013
    Sacramento, CA
    2,769
    Salt or the dreaded white stuff. You might also check your delivery and makeup lines.
    Dec 2015
    113
    No matter what methods we decide to use to add chlorine there will always be some sort of maintenance involved.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,253
    If any of you gents have a chance, would you mind providing info for this survey? Thanks for considering it.
    SURVEY - Liquid FC Dosing
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
