Thread: SampleSizer and using Taylor #9198 Test tube exclusively
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Has anyone noticed any testing discrepancies when using the Taylor test tubes vs the ones that come with the TF-100? I finally got the SampleSizer and like it so much for the quickness and ease that I've ordered extra Taylor tubes to use for all my tests. One strange thing I noticed though, is when I compared how I used to measure using the regular tubes (carefully having the bottom of the meniscus sit on top of the black line) and then poured this amount into the Taylor vial, the sample measures visibly higher in the Taylor vial. It's enough that the SampleSizer displaces the water to have it then measure exactly on the Taylor line.
    Was I filling the regular tube incorrectly? Is the meniscus supposed to sit on top of the line, in the middle, or below? It's a wider tube, so maybe if it's not supposed to sit on the top of the line this would account for the higher reading in the Taylor tube.
    I do wonder, though, how much does this difference affect testing? It seems like a slightly larger water sample might give slightly higher readings? Since I'll be taking advantage of the SampleSizer for my future tests it's a moot point for me, but I am curious since it might make the difference between being within range for FC or unwittingly too low.
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    Re: SampleSizer and using Taylor #9198 Test tube exclusively
    This came up yesterday in another THREAD.
    Sounds like Dave and OTP are going to look into it.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    JamieP's Avatar
    May 2011
    1,135
    Quote Originally Posted by bdavis466 View Post
    Thanks Brian. Dave made a good point at the end of that thread about repeatability, so therefore using the same tube consistently. I'll be interested in following that thread.
