Thread: New Filter - Sand in Pool / New Salt Sys - Low Salt
    Jul 2016
    Jefferson City MO
    2
    I just purchased an Intex Sand Pump/Filter and an Intex Saltwater system. I have them running to a 22ft Ultra Frame (10k gallon) pool. I've followed the set up instructions very carefully and have been running the two for less than a week. The first problem I noticed is the amount of sand in the pool. I've backwashed, rinsed several times but the pump still pumps sand in the pool (although less than in the beginning). The second problem is the "low salt" light on the salt system came on and it switches to sleep mode. I tested the water which came back at 2800 ppm. I added 40 lbs of salt which brought it up close to 3000 ppm. Every time we try to run the system (I've turned it off and unplugged it to try to reset it), it runs for a short period of time and then displays the low salt error even though I know the pools salt level is good. I haven't cleaned the electrodes (which does have white scale) because I've only had it a week and I've heard cleaning it is hard on the components. Any suggestions?
    22ft x 52in Intex Ultra Frame AGP with dual suction outlet fittings. 10,500 gallons
    Intex Krystal Clear SFP with 2800 GPH pump flow rate.
    Intex 120V Krystal Clear Saltwater System with Electrocatalytic Oxidation
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,230
    Re: New Filter - Sand in Pool / New Salt Sys - Low Salt
    If the cell has scale, you need to clean it. That also tells you there may be an opportunity to improve your water chemistry and avoid the scale.
    Sand can occur on a new install from a couple of sources. It may stop if it's because some of the sand got into the outlet side of the filter. It may also stop if there was too much sand put in. If a lateral got displaced, you would have to empty the sand, fix the lateral, and put the sand back in. I don't know this filter at all, but if had things like the spokes of a wheel at the bottom of a standpipe, those are the laterals.
    Remember not to swim with this pump running.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jul 2016
    Jefferson City MO
    2
    Thanks. According to the setup instructions, it is not recommended to add chemicals. Not sure how to change the water chemistry without adding anything. Also, I didn't see anything about not swimming while the pump is running. Why is that?
    triptyx's Avatar
    Apr 2016
    1,438
    What setup instructions, and is there a time limit on adding chemicals?
    You'll have to add chems at some point very soon after installation to keep a pool in balance.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    needsajet's Avatar
    Jan 2016
    4,230
    Not recommended to add chemicals?!? Is that instruction in context with some temporary situation or related to specific chemicals? You need sanitizer in the pool.
    Intex 2,800 gph Sand Filter Pump Krystal Clear 0.95 hp Sand Pool Filter Pump
    See the Frequently asked questions on this page.
    There's electrical gurus here who can explain it better, but essentially the pump is not double insulated from the water, and therefore should be bonded to the pool water and steel or other conductive parts within reach of the water. Bonding prevents shocks from voltage differentials caused by stray electricity. Stray electricity can come from a fault in your house or in the power transmission lines in your neighbourhood. I know it sounds like ghostbuster stuff, but it's a genuine and manageable risk. Leaving the pump off while swimming eliminates the risk for your setup, to the best of my knowledge.
