Thread: New inlet/outlet in intex 15x48 ultra frame questions
    Jun 2016
    Sterling Heights
    6
    Ok, so.. I'm new.. so please bare with my newbie-ness..
    I just installed the hayward in wall skimmer.... and WHEW.. that was intense, lol. But so rewarding when there was ZERO leaks. I now feel like I can conquer the world...
    So on I go. I want to install the hayward eyeball that came with the skimmer. And I have a few questions. I don't really want to hard plumb right now. And would prefer to use the 1.5 intex hoses that I purchased. Since this is a 15 ft pool is has the 1.25 hose inlets. Right now I have the original suction holes closed off. The skimmer running on the 1.5 hose. And the return running on a 1.25 hose with the original dinky outlet nozzle which I hate...
    Here's what I would like to do.
    1. Cut return to fit hayward eyeball, but I need to know what I need to hook it to a intex 1.5 hose. And the intex plunger. Or, I wouldn't be opposed to the ball valve I've seen people use. ( I found them at Lowe's, and they seemed really heavy? Are those not the same? ) I would need to know the parts needed to do that?
    2. I, think, making one of the original suction inlets may help draw the water to the skimmer more, so, I'm open to that. It's a 1.25 opening.. how would I make that tie into the skimmer connection? And be able to close 1 off if I decided I needed more suction from the skimmer?
    3. I have the intex robot, and love it. So, I need to know what I would need to rig up to get that to connect to the intex eyeball. OR, use the other former suction port as a designated vacuum port. This vac doesn't work on suction, it works on the return end, for those who aren't aware. I was suprised at this, but it really works awesome... I just need to figure it all out. And I think I get a plan, then I go look at the pool, and draw a blank. Lol
    Please help!
    I also think I have to create a "signature"? But haven't yet, so... my pool details are as follows.
    15x48 intex ultra frame
    2500 gal per hour intex filter
    Swg
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Re: New inlet/outlet in intex 15x48 ultra frame questions
    Welcome to TFP! I have the same pool just older model with only one suction side inlet. When I converted to SWG and sand filter I had to cut the old inlet / outlets out for the new returns and inlets. You should have no problem adapting the intex hose to the Hyaward eyeball. All I had to do was find an extra flat gasket to put in between the plunger and eyeball. I think I found them at Home Depot or it might of been a flat gasket from Intex. The only thing that might get tricky would be using your intex robot, you would have to use just the hose from the plunger valve if there are no adapters that would work for the Hayward eyeball. Or you might be able to make an adapter. Good luck and post some pics when you get it figured out.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
    mulia's Avatar
    Jul 2011
    NE Ohio
    100
    here's a hayward inlet outlet fitting
    [URL=http://s61.photo
    This intex adaptor screws into it
    here is the adaptor
    INTEX AGP 15'x 48", 4440 gals.,INTEX 2650 gph pump w/ 16" sand filter, Hayward widemouth skimmer,INTEX SWG-CS8110, 1 1/2" hard plumbed PVC, Lil' Shark vac w/ leaf canister, INTEX floating LED pool light, solar cover with polaris solar reel, Access pool steps 200600T, TF 100 test kit, "The Slime Bag" x-tra polishing 18" x 30"
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,528
    I have almost the same setup as you, Hayward skimmer and eyeball, Intex robot. Here's what I did to run the robot. He's hooked up to the hose going over the side, and with the valves I can run him and the regular return at the same time. Just a few bucks worth of PVC.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Sep 2013
    El Cajon CA
    126
    Quote Originally Posted by mulia View Post
    here is the adaptor
    Looks like you have it figured out.
    Mar 2017
    46516
    1
    does the "SMALL" end of the adaptor screw into the hayward fitting? I bought the hayward inlet but it is too short and wont let me tighten my plunger fully to make a water tight connection. I am wondering if the small end of the adaptor screws inside the hayward inlet so i can extend it and fully connect my plunger.
    I have a 15X48 intex pool and I am installing a sand filter that has the larger connectors and hoses so I am cutting the small ones out and putting in larger fittings to connect to the plungers.
    Thank you
