Thread: How to patch an 18 by 48 ultra intex pool?
    Jul 2016
    Los Angeles ca
    1
    Question How to patch an 18 by 48 ultra intex pool?
    Hi all! I'm so sorry if this was already posted. I'm fairly new to this and was not able to find my answer. We bought a brand new Intex pool that I guess was defective because after filling it up, we noticed a leak and found a small hole at the bottom vinyl. We drained the pool and want to know how to patch it. We tried the vinyl patch it came with and bought glue but it didn't stick and make the patch kind of shrink. What glue to I use and what patch it's so frustrating. Thanks in advance.
    Jun 2015
    Stockholm, Sweden
    250
    Re: How to patch an 18 by 48 ultra intex pool?
    If it was leaking brand new you should return it and get a new one!
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    I've used this with great results. It even works underwater. No need to drain if you do it properly. You do need to be fast when you do it and you have to figure out a way to stay underwater for a while.
    http://www.walmart.com/ip/Heavy-Duty...-Bags/52241279
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
    Oct 2013
    Los Angeles, CA
    87
    I've used a product called boxer it works under water as well and can be bought in Amazon
    Intex 12 by 24, Intex 2600 sand filter (soon to upgrade), deck under construction
