Thread: Help!
    Help!
    I've had my above ground pool 3 weeks. Due to issues with getting inspection done and vacation we had a delay in getting our plastic and rocks around the pool. It's a 24 foot round. Just my luck we had rainy days, and two heavy downpours that created several flooded pools along base of pool. I know the installer did a clay silt base, and it looks like some of that washed out from under the pool...I'm not 100 percent sure as I'm wondering if this is just what this dirt looks like as it's still soft and wet. It's definitely seems to be a different color than what it was after the pool was installed. Is this a major issue?
    Casey's Avatar
    SW PA
    10,438
    Re: Help!
    If you have water pooling around the pool from rain, you're going to want to look into a French drain to move the water away from the pool.
