Results 1 to 8 of 8
Thread: Green pool. Need some advice.
    Jun 2015
    Oak Forest IL
    20
    Fc 9.2
    Cc .6
    Ph 7.2
    Alk 80
    Cya 90
    Soo I know your gonna shun me but I do use the tablets with an auto feeder. My pool is green and it almost went away then came back. I put half gallon of liquid clorine I think it's 12 percent. My auto feeder is turned off. Just need a little help getting this fixed. I personally think my Cya is to high and need to dump some water but that's where the pros come in hehe.
    Feb 2015
    Chandler AZ
    926
    Re: Green pool. Need some advice.
    You CYA is high - do to the use of tabs in the auto feeder. You will probably need to drain some water and do a SLAM.
    Your test results are missing the FC and CH results. What test kit are you using? Are you familiar with the Chlorine / CYA Chart?
    Please list your pool info in your signature as outlined here: Pool School - Read This BEFORE You Post
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,575
    Sounds more like your POOL has shunned you----not us! One of our good test kits and a SLAM will fix it.
    Jun 2015
    Oak Forest IL
    20
    Sorry. I have a leslie kit but I think it'd a taylor but with there brand on it.. I had to get the fas dpd kit. My fc is 9.2 a cording the fas dpd kit and my ch is 140
    Jun 2015
    Oak Forest IL
    20
    I'm trying to update my profile buts not letting me off my phone. I have a 24 ft round 54in pool. Probably 14000 gallons I think.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,472
    OK, if you have FAS/DPD then you are set to go with a SLAM to kill the algae. Follow this process, SLAM
    Jun 2015
    Oak Forest IL
    20
    Off subject but what liquid clorinator would you recommend? Also how much would you recommend out of my pool.to get the Cya down?
    Feb 2015
    Chandler AZ
    926
    You can use Pool Math to calculate how much water to replace. You may want to shoot for a CYA of 40.
    Regular bleach from Walmart (8.25%) or chlorinating liquid (10%). You can even find 12.5% chlorine at various places. Be sure to check the dates as chlorine degrades over time. Here's a date code example: 16180 -- this indicated the 180th day of 2016 (near the end of June 2016).
    If you're on your phone using Tapatalk you may not be able to update your profile. Use the phone's internet browser to access the site.
    Gene
