Thread: high TA low pH
    backlit's Avatar
    Jul 2016
    Santa Rosa/California
    1
    high TA low pH
    Hello All,
    This pool stuff is a lot harder than I thought it was going to be...
    I just got an intex 18x9x52 (4545 gallon) vinyl pool about two weeks ago for my birthday. The local pool store told me to put in about 1/2 gallon of chlorine + 1/2 gallon of stabilizer to open the pool. My kids and I have been swimming pretty much every night since then. So that's a bather load of 3-4 people for the last two weeks. I've been running the filter for about 12hrs/day.
    So, I've been trying to do the test strips to keep an eye on things, but I haven't done anything "intentional" to modify/adjust the pool chem. I just picked up a taylor 2006 complete test to get a "better" account of where the chem stands. Here's what I got after testing last night:
    Temp: 84F
    TH: 250
    TC: 10
    FC: 10
    pH: 7.0
    TA: 210
    CYA: 40
    From what I can tell my TA is at least 110ppm to high and I should try and bring my ph up to 7.5 at least. But now I'm stumped... If I add Borax, it'll raise my pH but also raise my already high TA, right? If I use Muriatic acid to lower the TA, it'll lower the already low pH, right?
    Anyway, it's probably clear that I have no idea what to do and I could really use some help. Do I add Borax or Muriatic acid, and in general, which should I try to address first, pH or TA? Also, is that high chlorine going to bother anything, or is it okay to live with?
    Thanks a bunch!!!
    btw: here's what the pool calculator says I should do:
    Given TA of 210 and Borate of 0:
    Add 32 oz by weight or 28 oz by volume of washing soda or soda ash
    or add 63 oz by weight or 60 oz by volume of borax.
    Add 0 of muriatic acid
    or add 0 by weight or 0 by volume of dry acid.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: high TA low pH
    It is a PROCESS to lower your TA. If you can, lower your PH to 7.2, aerate to raise it, and lower again. Each time will lower your TA. Welcome.
