Thread: typical water level
    Jun 2016
    Lafayette, LA
    5
    typical water level
    What should the typical water level be on average above the skimmer openings for proper operation? I have two skimmer openings, each on either ends. As a side note, i've noticed about a 1" or two finger difference in elevation between them.
    Mike
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    triptyx's Avatar
    Apr 2016
    1,438
    Re: typical water level
    Interesting that they're are at different levels!
    The general rule of thumb is that the water level should be kept about halfway up the skimmer opening.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
