I am having trouble with my pool water. It is cloudy, has some pink slime and the test results at below. It is also eating up the chlorine tabs at about 25 tabs (1" tabs) a day.
Free Chlorine .14ppm
Total Chlorine 1.26ppm
Combined Chlorine 1.11ppm
pH 7.1
Hardness 88 ppm
Alkalinity (w/ stabilizer correction) 68ppm
CYA over 149ppm
Copper .3ppm
Iron .1ppm
Phosphate 0ppm
Pool store says the best way to approach this is to drain the pool (all the way if possible) and start over with fresh water. This is about a $2k refill. Any help or suggestions would be appreciated.
I am going for a third water test tomorrow to make sure their reading are accurate.
Thanks
pH 7.1
Hardness 88 ppm
CYA over 149ppm
Copper .3ppm
Iron .1ppm
Phosphate 0ppm
Thanks
